Xiaomi Mi Max
skrw105
hmm thats weird mine does not come with a pin , borrowed my bro's iphone pin but yea nothing seem to happen when i poke the hole
at the back of this manual.
Plastick
my set intermittently will have few seconds of touch screen 'no response'. wonder is hardware or rom. on global beta.
kandinsky
What's myippt for?
For NSFs and NSmen who still have IPPT/IPT/RT liabilities, can use to book sessions, etc. :(
https://play.google.com/store/apps/details?id=sg.mindef.ns.ippt&hl=en
MyIPPT is a mobile app and comprehensive IPPT companion that helps you in the management of your IPPT schedules and fitness regime.
Designed for all Singapore Armed Forces National Servicemen in Singapore, MyIPPT is a multi-function fitness application that lets you manage your IPPT, IPT and RT bookings, and also helps you stay on top of your fitness regime by tracking your training activities.
Plan, save your workout and monitor your progress. Set your goals, customise your fitness regime, and personalise it with your preferred workout music. Calculate your Body Mass Index to determine if you are in the healthy range. Exercising is not all about work, you can also have fun by sharing the details of your workouts with friends on Facebook and NS Connect. Locate the nearest fitness corner in your community and get your friends to join you in a fun workout session together!
jace88
Is it possible to disable Google apps for Music and Movies/TV shows? On my other Androids, I can uninstall the updates and disable them but on my Mi Max running MIUI 8, the disable button is greyed out... more annoyingly they keep showing up in Play Store for updates.
Guys, just got my Mi Max. Any place I can buy to put tempered glass instead of Screen protector? Screen protector are more prone to have scratches which I dislike. ~
Read this thread. There's known issues with tempered glass screen protectors due to the curved edges (slightly) meaning that tempered glass either cuts short (i.e. it doesn't cover the whole glass) or it covers it but it won't stick down so you see these thin white lines on both left and right side.
If you're still set, there's a few places which will do the 'smaller' tempered glass for about $10 (eg one of the Mi stores in SLS).
I personally have one of those but from Hitec Mobile in Bugis Junction (hard to figure out price since they negotiated everything with another phone in a bundle), but if it were up to me, I'd wait for a healing shield. I found on my S7 Edge with curved glass, the healing shields are the best way to go.
Based on a rec in this thread I bought a "healing shield" from Simder Trading. It cost me $8 and the fellow helpfully put it on for free. He said it was similar to tempered glass. In case you want to consider...
Sent from Lung Tien Xiang {Mi Max} using GAGT
SPEED
so from the box, 1 sim at 4G, the other sim can be at 3G?
yes
i have 2 sim cards
main one will be 4g the secondary will be 3g
even though if your secondary sim is 4g ready
the phone only supports 4G+3G
not both 4G at same time
loster
yes
i have 2 sim cards
thanks. at least still usable when 2G is remove next year
jazzman80
no, I don't think it can be disabled.
that is the second reason I rolled back to 7 besides low volume.
is the transition big between the two versions?
so far I'm happy with 7314
jace88
yes
i have 2 sim cards
Maybe I'm missing something but why would anyone need second sim to be 3g or 4g unless the legacy networks are turned off... Oh wait maybe I answered my own question.
Phen8210
btw if anyone looking to buy is curious, this tablet can playback 4K video from youtube stream directly from the browser in desktop mode with 0 issue.. enter exit fullscreen smooth as silk
jazzman80
SOT 12hrs with 42hrs standby,left 10%.never clear any app,just let it run.
and blasting music through speaker for couple of hours, really not bad.
still on 7314.
johnsonheng
why i cannot apply the 30 dollars discount code on lazaada.
anyone can guide me
Nakedtoes
Means use phone in tethering to desktop? Or u mean cast to desktop?
