Xiaomi Mi Max
Homiesun
Micro SD Card for Xiaomi Mi Max 32G
I just bought a Xiaomi Mi Max 32G phone from Singtel on Combo 2. Loved the set and had it updated to MIUI Global 8.0 Stable (8.0.1.0(MBCMIDG). Insert a Sandisk Ultra 32G microSD and it is working with no problem. Then I decide to try using a Sandisk Extreme 128G microSDXC UHS-ICard (which was formated to fat32 and had been working in my Samsung Tab S). This time,Xiaomi Mi Max could not detect the Sandisk Extreme microSD card despite several trials. Could some kind users/experts please help me or share their experience on using microSD card (Brand, type or max size) on this phone? Thanks in advance.
Nakedtoes
I using sandisk 128gb no problem... $100 save from 300 is more then 30% off.. Definately worth it.
Nakedtoes
This phone is good that quite many upgrade to 64 or 128gb from 32gb..i m considering it also when global rom out
Compact7
Surely this phone must display your gmail saved email address? Anyway to dispable this? Also how to import sim contacts? First time miui, quite confuse still
hlw8888
IMHO, Smartcell has been the most trustworthy!
Currently the Gold color is out of stock.
The silver one is available.
Remember to use a voucher code to further reduce the price. For that, do a search for lazada discount codes or promo codes... :) It can be as much as $30 discount.
http://www.lazada.sg/xiaomi-mi-max-32gb-exportsilver-8897953.html
is this a sealed set with global ROM installed?
is mi max gps ok? i am tempting to get one for my upcoming trip since google map on a 6.4" screen will be useful. :D
Homiesun
May I know your Sandisk 128G microsd card used successfully in Mi Max is which type - ultra, ultra plus, extreme, or extreme pro? I could not get my Sandisk Extreme 128G microsd card to work in Mi Max?
cscs3
So the MI MAX 128gb version renamed as "PRIME"? 400+ is 100 more than 32gb local set.
To be exact, $200 more. Current Mi Max is around $249 +/- depending on where you buy.
Btw, I believe is going to be around $400 or less for parallel imported set. This means if you are going for local set @$345. You must well wait for the 128G parallel imported version. Same situation as current Mi5 local set vs parallel imported set!
cscs3
Seal set as according to one of my friend.
jace88
I find GPS is a bit slow sometimes and wonder if that's because of MIUI trying to do power management/implement additional controls over whether it uses actual GPS vs. wifi to determine location.
Alwaysb
Hi, has anyone experienced the touch screen not very responsive?
I am running miui 8 and using 2nd space feature cos i have a work sim and personal sim. I use this feature because i wanted to seperate my contacts.
But i hit a problem. I realised my sms record can only be retrieved in main space despite the message was meant for space 2.
Anyone has solution to this? TIA
otacon
I read that most xiaomi phone GPS slow
kandinsky
I have it set to High accuracy mode, and it locks on pretty fast outdoors. On par with my other devices.
