Xiaomi Mi Max
trichard
Hi, has anyone experienced the touch screen not very responsive?
I am running miui 8 and using 2nd space feature cos i have a work sim and personal sim. I use this feature because i wanted to seperate my contacts.
But i hit a problem. I realised my sms record can only be retrieved in main space despite the message was meant for space 2.
Anyone has solution to this? TIA
Yes I feel that the touch screen not responsive....
kandinsky
And I find that it's over responsive, lol.
What you guys can try is to go into Additional Settings > Developer options > and toggle on the "Show touches" and the "pointer location". This will help you see if there are moments when the screen is not registering your touch.
pilico
This phone is tough as f***. I dropped my phone god knows how many times, dropped from 1++meter vertically, flew across 1++ meter (my bro accidentally hit my phone) nothing major happen to the screen, just some scratches here and there on the on the back, sides and some hairline scratches on the screen.
And today, i dropped my phone on the road when my friend was giving me a ride on his motorcycle, travelling around 50km/hr. One van and motorcycle drove past it and i was thinking wah this time die liao need to change phoneliao but when i retrieved my phone, i was dam shock, there was no damage on the screen (mayb becos landed screen facing up) just tons on scratches on the back and the camera lens(glass) shattered but still working fine.
Best 300++ phone ever.
EDMW is that way leh ↗️
Sent from Lung Tien Xiang using GAGT
cscs3
Could be the temper glass too thick...
I tap tap screen to turn on sometime don't work....
tap tap screen dont work think is normal. My friend use without screen protector also like that. My old Mi4i also the same.
csoyzx
I think many pages back, some members had mentioned it but never show method. OK la, I will do up the steps now for the benefits for all members.
Basically it is to put the phone to EDL mode (Emergency download mode) and flash using miflash beta. I believe the shops do it this way to flash the phone to "global rom". OK info as per below.....
NOTE: TRY AT YOUR OWN RISK.
1. Download the preferred official fastboot rom for the XiaoMi MI Max.
2. Download and install the official miphone aka miflash from here. This will install the neccessary drivers for detection.
3. Download and install the miflash beta from here. This will be used for flashing the fastboot rom. The installer will installed as XiaoMiFlash
4. Unzip the fastboot rom
5. Run the XiaoMiFlash as administrator. Click on select and point it to the root folder of the unzipped fastboot rom. e.g. C:\fastboot_rom_folder_name. After that on the bottom right, check on "clean all" options.
6. On your phone, get to developer mode to enable USB debugging. This step might not be necessary though, but before my phone gotten into boot loop after flashing from Mi PC suite, i did enable.
7. Turn off your phone. Press and hold vol+, vol- and power button to get to EDL mode. Note that the screen will not show anything, you will know it has power on as it will have vibration upon bootup.
8. Connect phone to PC, wait for it to detect and install the necessary drivers. Refresh on XiaoMiFlash and your phone should show up, e.g. COM1. If it does not show up, try refreshing a few times, else disconnect and reconnect your phone.
9. Click on flash and wait. This part a bit scary, you can only see the progress on your computer as the phone screen won't show anything!!
10. After success, unplug and reboot your phone by holding on to the power button. The phone will be setting up itself to the new rom. After which, enjoy the newly flash rom.
Cheers!
Thanks for the info bro.. Just wanna check if the phone gets hot when playing games or watching movie? My z3+ gets really hot sigh..
azbyza
Lucky for you, ignore those skeptics from EDWM.
