Xiaomi Mi Max
i1magic
I tried uploading video to YouTube but it couldn't complete.
Anybody encounter this or can try and let me know? Please set video privacy as "Unlisted", so that the video uploaded will not be searchable by public.
chobits
High accuracy. If you wanna save batt then use the battery saving, or turn off when not in use. For me, at end of day still 40-60%, so I don't see the point in conserving batt when there's plenty of juice to be used. I carry a phone with big batt so I don't need to worry about things like that
Haha you have a point there.. :D Although I came to realize my other phones also bugged by Google Play Services draining battery issues, but this phone stamina really power. I don't think my other phones would have lasted so long.
i1magic
Anybody got this issue too?
chomechome
thanks. came across link #1 on my day1 but seems like the fix is applicable on the global stable? iirc, the rom im on from out of the box was already newer than the one in the site. right now on beta instead, doubt can flash that fix? or die die have to go back global stable liao
Hi I just upgraded to global stable rom 8.0.2 it seems solved the problem. You can try.
By the way I realized this problem only affected play store web surfing is OK. You can run speed test to confirm.
1982-1994
i agree screen on time on MM is the best but I don't think the standby is as good as kitkat,due to the constant running of the android OS.
overnight drain 6% on MM VS 2% on KK in 8hrs.
guess we can't have best of both worlds.
FinchGuy
OT a bit: How to turn off the rich preview thingie in latest version of WhatsApp? Takes up screen space. TIA.
Geo
Has anyone been to Mustaffa lately and did you see 64GB/128GB version there and what's the price?
For some reason, most of the 64GB/128GB listing on Lazada are gone.
Plastick
yes you are right, it is affecting downloads in playstore alone.
Global rom ! Miui 8
global stable? im on global beta. think i would have to flash back to global stable liao...
chobits
I haven't received it too.
I haven't received too.. But when I press download updates, it was downloading something! Battery was dying then the update didn't go through. Tried finding today and it's gone.
Edit: It downloaded and prompted me to restart my phone and when I checked, still MIUI 8.0.1.0 -_-'
