Xiaomi Mi Max
Oinkize
been using the phone one week.. very happy with the phone.
just that charging takes very long..
is there any charger that I can buy to speed up the charging?
please advise.
thanks in advance
Buy a qc 3.0 charger with good cables. It will help.
amazingone
Does any of local telco sell this model like the redmi note3? Looking urgently to get a set? Saw it at challenger but not sure if their prices are competitive?
Sent from Xiaomi MI 4I using GAGT
Challenger sells at the official retail price, which will be same as telcos too.
If you want some discount but prefers a local set, you may get it from Xiaomi's Lazada store and apply relevant discount codes for extra discounts.
Sent from Sumire using GAGT
nomoney25
Note 3 and mi Mac uses the same type of cable. There could be a possibility of faulty cable or charger. Try and set of cables and charger to confirm...
This charging problem appeared after using for 2 weeks. Don't think is the cable and charger problem as I have tried using xiaomi power bank too. May I know how long to charge from 0℅ to 100℅ using the default charger?
linjc28
Hi. My local mi max was bought from kaisa mobile just 2 weeks ago. I realised that there are charging issue with my USB port with frequent intermittent charging and the battery was draining while still charging during use. It was not like that initially.
Can I bring to xiaomi Singapore service centre to fix it ?
Sorrie, what the price u bought?
Adelyte
I've following this thread and I find it confusing as some of you wanted to switch from global rom to china rom. Is there any issue with the current global rom? Is soft sound volume one of the issues?
No la no problem. Global rom is good, but I prefer China rom due to the Chinese apps.
Geo
I see. You mentioned your 64GB set came with global rom, may I know which shop is it? I am trying to get a 64GB one that comes with global rom to save me the trouble of flashing. Thanks.
Compact7
For who may interested, there is a local silver 3/32gb set in carousell calling for 279 abt n hr ago. Seller listed it as sealed. If true shd come with 1 yr warranty by xm. Just share only. I am not related to seller at all.
trichard
Check the charging current...
Adelyte
I bought from NSE.
My Fren also bought from NSE but gotten a China ROM set. Guess it's random, but I think u can msg the seller to request.
Oinkize
I bought from NSE.
Please beware that the global rom might be a 'modified' rom.
kandinsky
Should be between 3.5-4.5 hours, depending on whether you're using it and whatever settings are on or off...
Compact7
I am using original charger and cable 30min 20%. 2.5 to 3 hrs 100%.
Btw,is there any setting to enable quickcharge in miui 8?
iguoh
I also read elsewhere that you need to be on developer ROM in order to unlock bootloader. But isn't unlocking bootloader one of the ways through which one can upgrade to developer ROM? :s22:
Flashing to Global Developer ROM worked for me. I was unable to unlock my bootloader with the unable to verify device problem for days. I swapped to Global Developer ROM and the problem disappeared immediately.
