Xiaomi Mi Max
CPwanton
got 1 month warranty, top rated on lazada also
just go whack with 200 off 30 from lazada = 194 :s13:
don't think it's india set though since the 1 and only review says it comes with 3 pin charger.
3 pin charger should be from which country (except Singapore)?
Lil_d3viLz
Anyone has idea on how to transfer .mkv video file ~9.9gb from PC to sdcard?
I can transfer to Mi Max internal storage but not the sdcard formatted by mi max?
In the end i had to transfer to mi max then re-transfer to sdcard internally...
Niaoson
Possible to have the clock on even when not charging?
How is the battery consumption?
nomoney25
Wah, that good to know. Do you happened to overheard what's wrong with the export set that the uncle has?
Buying export set is basically a gamble. But so far, from all those that are here who bought, seems like all the set are ok. For the price difference, one has to decide whether you want warranty of pay a lower price.
Not really sure what products they r talking about. The guy on counter explained to them they don't entertain export set. Advise them better to get from their physical shop or from telco or changeller
bladez87
dont entertain ah. so even pay money also cant fix. Zzz
luei74
The Mp3 soft sound issue till now they still ignore and didn't bother to fix it...
Using built-in Musics MP3 song got to set to 70-80% of the vol, if switch to MeRadio the sound will suddenly Max out...
:vijayadmin:
:s45:
:mad:
Plastick
am i getting deaf or the in-call volume really soft? at max volume & global beta
