Xiaomi Mi Max
nomoney25
A update of my mi max which has usb charging port issue. They checked thru the system to confirm mine is a local set thru serial number as my mi max is bought from kaisa mobile. Then they proceed to repair it in 1 and half hours although I was told to come collect 2 hours later. By the way. The phone was just bought 2 weeks ago.
For those who thinking of whether to get local or export set. The after sale warranty service within a year should be the factor. Happen to withness a uncle request to fix his product was rejected as it was an export set.
zenify.me
Can describe the charging issue?
bladez87
which is better? mi max or redmi note 3 pro? is the size of max an issue?
1982-1994
MIUI 7 is the best.
66hrs, 100% on 4G other than when sleeping. no wifi.
i1magic
Wah, that good to know. Do you happened to overheard what's wrong with the export set that the uncle has?
Buying export set is basically a gamble. But so far, from all those that are here who bought, seems like all the set are ok. For the price difference, one has to decide whether you want warranty of pay a lower price.
1982-1994
verdict, I prefer to be on Starhub network for better battery. it's like 1% drop per 3.5hrs compare to M1 of every hour drop. thanks to fast dormancy.
1982-1994
see the battery graph over 3 days, is not steep at all. the steeper it is, the higher the power consumption..
usage,
opera mini, poweramp (both speakers,max volume and earphone)
bladez87
if we are willing to pay for the repairs, donno the service center will do it anot.
zenify.me
anyone bought from lazada seller swooop before? 32gb at $224
got 1 month warranty, top rated on lazada also
just go whack with 200 off 30 from lazada = 194 :s13:
don't think it's india set though since the 1 and only review says it comes with 3 pin charger.
ekardo
how to get the 200 off 30 voucher?
