Oinkize
- May 22, 2009
How to mute?
Setting, additional setting, screenshot, screenshot sound.
How to mute?
Emh.... I never watch YouTube while on the move so my only problem/concerned still between the Radio Apps and the built-in MP3 player...
Let me try out yr YouTube link while at home later....
If they don't bother to solve this minor "soft vol" for us, they should at least give us the secret code to let us manually adjust the vol (similar to the old MTK chip)
Hi, how is the phone in terms of comfort while using it? Is it quite awkward to hold it?
Is there any diff between 16GB and 32GB?
Thx bro....Setting, additional setting, screenshot, screenshot sound.
Ok!
Tested all media sound, be it mp3 or video. Volume output on both the speaker and headphone are been normalized or improved so much in that context. No complaint about it now with 8.1.2.0.
However.....somehow my YouTube playback volume on headphone is still damn freaking low! I have tested few YouTube videos. Same result.
The YouTube volume output on speaker is normal though...!
Is that a problem between YouTube and MIUI8 on headphone? I'm blur sia!
Folks,
Can you try this YouTube video on your headphone and then speaker respectively to see if you get a different volume output loudness by setting both the headphone and speaker volume level at 50%.
https://youtu.be/abOhx2YtPyM
https://youtu.be/i1Xk4dKT3zw
https://youtu.be/BPEsQdhN-xw
2x memory difference.
Bro Kelvin, tested on your 3x Youtube musics link, yes it's the same issue that I'm encountering since day 1.
Both the Youtube link musics and my MP3 Musics, need to be at least 70% for normal use. But Radio Apps (Meradio, 100UFM, never try on Tunein Radio), the setting of 70% will be too load and need to level down ~50% of the vol level.
Be it in Phone speaker or Headphone (try out KZ-ZST IEM with 18 ohms Impedance, BSX Audio Basic ear phone). The o/p sound of the phone speaker and the ear phone are equal.
The only problem still lies on the Sound of the Apps Radio VS FM Radio/MP3/Youtube. The DAC o/p level suppose to be the same, still puzzling why there's a different between Apps Radio VS MP3/Youtube. Coming from Redmi 1/1S, Redmi Note 2 never encountering this issue.![]()
I read that low vol playback on mp3 file is common issue in xiaomi. They like .ogg file. I tried to set my ringtone to mp3 and sound super tinny and low. Back to their ogg format then fine. Xiaomi seem not keen to overcome this complaint at all.
The internal memory doesn't make any diff right? Since can put external card.
Phone models with the larger storage capacity tend to be faster (pretty technical explanation), I would say 3gb Ram is the minimum standardfor an android phone, plus sd card storage is slower and can't install apps
