linbeier
- Jun 21, 2012
Are you on Global Stable or Beta?
Global Stable 8.1.4.0 here
I got this screen protector. Cover nicely.
Item : Tempered glass screen protector for Xiaomi Mi Max
Price : About SGD$2.70
Source :
https://www.aliexpress.com/item/For...32699452701.html?spm=2114.13010608.0.0.kcqowC
When I first flashed to 8.1.4.0, this happened. But it went away after a reboot.Updating now. See how later. If still same I ask refund
Try charging with a different charger / cable combo. Could be faulty stuff shorting your phone.Once I unplug the phone from charging, I can unlock with fingerprint liao leh.
Bro, what is the status? Done flashing successfully?
Have been doing some research on unlocking bootloader and flashing. It seems approval from xiaomi to unlock will take 10-14 days!
Has anybody requested unlocking approval before? How long did it take?
Apparently the reason to lock is to prevent stolen phones from being reflashed easily so hence the added procedure. But I am just wondering what xiaomi does to check before approving the unlock request. Why do they need 14 days!!!!
Sent from Xiaomi MI 4I using GAGT
It went on and on for 1 hr and I pulled off the cable. Phone still ok. When I tried to re-flash again, it flashed within 1 sec and "success" but phone was not updated.![]()
Does any of you encounter this?
Cannot unlock the phone with fingerprint scan when it is charging?
hi, anyone here able to mute the camera sound in whatsapp? on miui8 now. tia.
if your phone is on silent mode , the camera wont make sound
But if I want official global stable ROM then have to unlock right?you really dont need to unlock bootloader if yu want to go over to CM14 or anyother ROM , TWRP can be flashed from EDL mode so no need to unlock bootloader.
Try EDL FLASH and perform a manual 1?
This is my screenshot using FASTBOOT mode. Something isn't right. 1 sec to update but phone was not updated.
Tried entering EDL mode by pressing both Vol +/- and Power. Entered a black screen and what should I do next?
Currently is therr any casing for mi max that is similar to spigen carbon black one?
I am using this now
Do the update via EDL not fastboot. Blank screen is correct. You should be able to detect COM instead of the fast boot device ID (ede****)
By the way bro, how to get the 3rd party converter and how much is it?Thanks bro for your sharing, will get a MiMax from Singtel next month![]()
