Xiaomi Mi Max
justln
Ah, can't apply $60 voucher for Simder cause they put it as daily deal. Newstead can use cause it's a group buy price, haha.
kelvinti
Hmmm.... In that case, use it on Newstar... Kekeke. :)
$437 - $60 = $377. Not the best price but considered it quite reasonably low already. May be can also apply its shop coupon.
Can hoot, man! :)
kelvinti
So far nvr kena auto reboot on latest firmware. But issue of need to reboot to connect to data after airplane mode is still there.
One thingy i dislike most is the pull down toggle go home right after you pressed on it, say turn off wifi.. Need to pull it down again to on data, then again to on hotspot... Lol
Ps: just discovered the toggle can stay still there after touch by turn off "collapse after touch" :p lol
Wahaha!
By default, it is turned off one mai..
You must have turned it on by accident lor.. Kekeke.
Nakedtoes
Those charge long long one install Ampere see the current how much.. Change cable and see if still same likely is yr charger lousy. The latest few firmwares mi max is super particular with quality of cable..the reading should show above 1A usual reading is 1.5 to 1.8A plus 400ma is the real current reading. .
zeroflame
no need root for that just google for ogtube and use that no advertisement and can download from youtube
Thanks for the recommendation on ogyoutube. Can download n do floating window. Fantastic for mi max big screen multitasking
leoch037
let's say my max is a china set loaded with global rom, will a factory reset returns it back to china rom?
