Xiaomi Mi Max
justln
In that case, should buy from Shopee liao! :s22:
I'm waiting to see if Simder will remove the Daily Deal, really gian the 6 months warranty. :s13:
Already order this shiny casing from Taobao. :s22:
https://detail.tmall.com/item.htm?id=536020874970&_u=t1pe8mnma2d4
kelvinti
This is the shop which doesn't have any warranty, right?
@kelvinti, did you suggest that folks either go for 3 GB Ram / 32 GB HDD or 4 GB ram / 128 GB, and skip 4/64?
Sent from Xiaomi MI 3W using GAGT
You either get the 3/32 if the storage is enough for you or go all the way for the 4/128 if you want a better performance and have higher budget!
Don't get the 3/64...not worth coz it adds extra 32GB of storage only. No extra ram and no extra core/faster cpu in that context.
The extra 1GB of ram on 4/128 really help to reduce lag and prevent lag from kicking in too early in prolong usage of multiple apps be it in the foreground or background not to mention a better cpu.
For reference. The speedy Samsung A9 Pro (2016) is using the SD652, same as Max 4/128!
justln
Bro, you bought from TB directly or via some buyers / help here from SG? how they ship to you?
Can ask ezbuy buy for you using buyforme, or you can ship to their address and use shipforme which is cheaper. But a word of advice, recently their service has been sheet due to heavy traffic from 11.11 and 12.12, I had to chase them almost 2 weeks to locate a parcel in Singapore. So prepare to wait.
Else Taobao ownself can ship direct to Singapore using 4PX but more expensive. Can try ask in Taobao threads in EDMW.
kelvinti
Seems like can do an OTA.
Wow! That is super fast! Congratulation, bro! :)
You mean 8.0.3.0? Do a screen print to show here!
My Simder's 128 is still don't know where LOL! Still "In Processing"! :s13:
However, I cannot "make noise" coz it is stated clearly ... "Get by 28th to 31st December" .. I can only make noise "next year"! :o:s13:
i1magic
sjchai75
I'll sent once I got home.
I think your Simderrella bump up the price maybe due to lack of stock...
cokiee
Ah, makes sense then if it's 3/64 and not 4/64. I might go for it if it were the latter, but else then 4/128 @ $4xx? Makes more sense from a future-proof perspective.
