Xiaomi Mi Max
lumpyme
not sure if anybody else experiences this, but i realised that my mi max has a much poorer connection speed as compared to my lg g4 despite both phones being on the same network provider and has full network reception
so after a lot of troubleshooting and debugging and even upgrading to miui 8 with a full reset, the network still remained as bad
later found out why, the apn protocol was ipv4/ipv6
after switching to ipv4, the connection speed returned to normal
amazingone
lanzhu60
Hi all,got mine frm Nse ,and notice thers slot of add popping up . Any way to prevent it from popping up? Thks
CrucifyMyLove
u mean recommended apps when u open a folder? if yes, tap on the name of the folder (like u wanna change the name of it) n u can switch the recommended apps off
lanzhu60
My ph ver is 7.3.11.0 .. hw to flash to official rom ?
currently wat ver u guys using ? When I try to update via updater ,it prompt me to connect to network. But I'm already connected to WiFi. Able to surf n update apps via play store.
Snowblind
I was having similar issues with pop-up and unable to update due to not connected to some Wi-Fi. I will update and show the link once I get it done. Tentative, apply to unlock bootloader. The link is on one of the earlier pages. Look for it.
lanzhu60
Thks for e reply. I have apply n currently waiting for reply to unlock. Still figuring out e steps to load e rom. Do share once u got e info. Thks
anirudhks
There is a app cloner on playstore which does the same as miui 8 https://play.google.com/store/apps/details?id=com.applisto.appcloner&hl=en&referrer=utm_source%3Dgoogle%26utm_medium%3Dorganic%26utm_term%3Dmiui+8+whatsapp+cloned+folder&pcampaignid=APPU_1_ie1nV_yfC8jwvgSX6JfgDA
bikoyski
firmware
what firmware are you using? The one I have is the one installed by Simder when I collected it. Notifications don't work on it properly. And I have to keep rebooting my phone at least once a day.
Anyone on the developer ROM? Can I update to Global ROM (when it comes out) from Dev ROM via OTA?
bbcccc
notifications dun pushed in properly is quite a common prob for xm phones
m using default xm rom n enabled everything I kn plus permission everything liao but still kana delayed for whatsapp n line notifications
hv to open the apps for the notifications to be pushed in
