Xiaomi Mi Max
bikoyski
notifications dun pushed in properly is quite a common prob for xm phones
m using default xm rom n enabled everything I kn plus permission everything liao but still kana delayed for whatsapp n line notifications
hv to open the apps for the notifications to be pushed in
I will try the DEV ROM tonight. I will just have to read up and find out how. :)
amazingone
If you use the Global ROMs may not have such problem, as it has Google CTS push services available, which apps like WhatsApp utilize for its push notification service.
CN Developer ROM may not have such a problem too, at least from one of my flashed Redmi 2.
Sent from my Rice phone using GAGT
bbcccc
used to owned a redmi note 3 local set with global rom
same issue too
notifications dun pushed in until manually open app plus the wifi keep dropping on the redmi note 3
Just Me
same issue too
The Wi-Fi drops because this model seems to have poorer reception when used behind a wall as compared to other brands like Samsung or Apple. And it likes to alternate between 2.4 and 5Ghz depending on the Wi-Fi strength. When I'm close to the router, it jumps to 5Ghz automatically.
Sent from Jiak Liow Bi phone using GAGT
maxlovely
i think you can't update global OTA to develop rom. At least I tried that with my mi4i, can't update, need to use miflash to flash with fastboot global rom.
what firmware are you using? The one I have is the one installed by Simder when I collected it. Notifications don't work on it properly. And I have to keep rebooting my phone at least once a day.
Anyone on the developer ROM? Can I update to Global ROM (when it comes out) from Dev ROM via OTA?
maxzone
i tot there is no global rom available for mi max at the moment. just curious what is the rom that smider loaded in their mi max
maxzone
Just curious what is the ROM version that smider loaded in the phone. I have checked with them and they say it is global rom, but when I told them there is no official global rom available , they never say anything and just say google play is installed
Very suspicious and hope it is not a modified or tempered ROM.
May I know what is the ROM installed in your phone
maxlovely
Yeah, I know there's no global rom for mi max. Those "global" rom in the mi max are probably downloaded from miui forum and simder flash into it.
Do a search in miui forum, many modified rom available.
zeroflame
China man photos took from mi max after update to miui 8.
much better quality..can't wait
bbcccc
For notification, can set the app to autostart.
Go to default security app...permission...autostart
and toggle the app you to enable autostart.
Then reboot and try
done everything le
whatsapp n line still delay
but once u open n reply, the nxt 30mins very smooth.
after tt, as long u nvr open n use the app, notification still kana delay...
bo bian, hv to mk it a habit to open the app whenever I use the fone
lol
heng8888
done everything le
lol
I just configured whatsapp autostart too, power off/on & tested, it worked!! Instant notification even after whatsapp is force-closed!!
bikoyski
Yeah, he did show it to me and mentioned Global ROM but I know better coz I've been checking the en.miui forum everyday.
It says
MIUI Global 7.3 | Stable
7.3.14.0.0(MBDCNDE)
bikoyski
Btw it's not a dig at Simder. It's a great shop and competitive pricing. I just wish they'd not resort to such sales tactics. Anyway, I really like the phone and I know how to flash 'em so.... no harm done. :)
