Xiaomi Mi Max
Aicirt
Erm. India's mi phones are all on global ROM.
As long as India release mi max, it means mi max will have global ROM...
Does that mean for the export set that we buy now can get auto update officially via the phone itself and don't have to worry about rooting etc
pilico
I believe the rom of the export phone has been modified, i don think you will receive auto update.
bbcccc
the first batch of 32gb I got from simder n first batch of 64 from newstar all comes with official china roms so update no prob...
lanzhu60
anyone using 32gb with modified rom 7.3.11 from seller... mind to share the detailed method to update the rom ?thanks
lanzhu60
hmm for mine frm nse, it comes with modified rom whereby it cant be update via updater..
maxlovely
Do a search in this thread, someone post the method to flash to official rom. Or simply request unlock boot loader from Xiaomi.
Once your phone is unlocked then is very easy to flash your device.
lanzhu60
yes, did a search n thers a no of methods which is bit confusing.. after unlocking, what method is use to flash?
s1mple
Any idea to install google play service on Second Space Miui8 China Dev?
Mine keeps crashing :(
lanzhu60
Go page 82 and follow guide. Mine had the same issue.
thanks, currently trying. notice the below,
- flash_all.bat (dont see tis file, closest file i see is flash_all)
-after choosing this file, theres no option to press "ok"
u encounter tis?
maxlovely
Once your device is unlocked, download the miflash and fastboot rom to flash.
But first is to unlock which requires request to unlock, wait for few days and use the verification code to unlock. Some ppl got the code also cannot unlock.
Snowblind
u encounter tis?
You will need to enable extension in ur Windows to see the .xxx
anirudhks
the ppl who got code but unable to unlock is a simple solution , i had this and was going crazy when i was not able to unlock , there is a guide where actually on the phone and on the computer you need to login to the mi account with your phonenumber not email or account ID , then only can unlock .
lanzhu60
currently my rom ver is 7.5.2... but dont seem to find much info about tis rom ver... anyone got idea
