Xiaomi Mi Max
benny888
Play Store Error DF-DLA-15 While Downloading Apps
Just got my mi max from newxxxx but having problems with google play store, can't download a single app because of error above. Anyone having this issue? Notice build version is 5.10.30
Googled around and try clear cache but did not work.
Just go to settings/installed apps and clear the Playstore data. Restart phone and try again
I faced similar issue on my first attempt to download on playstore too
My phone came with a custom 7.3.14 global rom
tech_oasis
Tried and failed. Forgot to try it when collecting phone :(
cscs3
If your phone come with the "modified" custom global rom. I suggest you wait for official global rom before trying out these apk from "unknown" source.
cscs3
Ya lor same. That's why in the end buy export set instead...
Support you. I normally suggest official warranty set. But Xiaomi.sg price is way too high, and most important dead slow to release to Singapore market.
kelvinti
Tried. Now can't open. Play store attempts to load and minimize by itself :eek:
You have got to clear cache, clear data of all google related apps.
Reboot your phone and start all over again from scratch according to the correct sequence of installing Google Installer > the 2 google apps.!..:s22:
Hope this helps! ;)
DRAGONGUY
Was it me or just my imagination.... samsung galaxy n4 earpiece is working brillantly well on my mi max than on n4 itself :s13:
Anyway i bo liaoz today, so i use the hp until 0% n charging it using normal n2 charger (5v 2a). 1.25pm start charge at 0%, 6.11pm at 100%. That is around 5 hrs less.
Ya, it's a bit long i know. However.... during charging, i play games, surf net, download music at 60% of the time. :D
So i think it is quite safe to say that, using normal charge 5v 2a with phone turn on and not touching it, is around 3hrs to 3.5hrs from 0% to 100%.
Just my assumption. ;)
kelvinti
Xiaomi audio sounds good. No doubt about it.. :)
My LG Quadbeat 2.0 headphone works brilliantly with Xiaomi phone. Awesome audio output quality with selected Mi Audio profile.
Audiology93
Definitely one of the better ones.
Stellar audio output
The Xiaomi Mi Max got perfect scores in the active external amplifier part of our audio quality test. The smartphone's output was clean, while its loudness was up there with the best, making up for one of the best showings out there.
Even more impressively, plugging in a pair of headphones causes next to no distortion - outside of a moderate hike in stereo crosstalk there are no affected readings. The volume levels stay high, too, for an impressive showing.
http://m.gsmarena.com/xiaomi_mi_max-review-1448p7.php
tech_oasis
Hope this helps! ;)
i cmi :s13: downloaded and installed must have apps. wait for global rom to be released.
Thanks
pilico
Xiaomi has the enchance software for earphones so i gues that is why it sounds better on xiaomi phone.
ferocity
There is one listing on lazada for the 3gb/32gb model going for $309. After factoring in discount code($20-25 max off depending on bank specific) + shopback cashback(2 or 4% depending on whether you are new or returning lazada buyer) + credit card rebates if any, the final cost of the phone would be around $270+.
i1magic
Any such lobang for the SD652 Mi Max?
I am waiting to see how much Mi Max SD652 64GB will be selling in Spore. If it is >$399, think will just buy export set liao.
Lamwm
List price from official xiaomi China site is RMB1699. Around SGD345. I guess S$399 should be just right for Singapore version. $50 for local warranty.
