Xiaomi Mi Max
cscs3
List price from official xiaomi China site is RMB1699. Around SGD345. I guess S$399 should be just right for Singapore version. $50 for local warranty.
RMB1699 is for 64G version I guess. RMB1499 for 32G version.
In general, if you buy it outside Xiaomi store (at your own risk). They usually throw in free case and screen protector.
walkofwinners
looking forward to this phone once it is launched in sg! currently using a redmi note 3 which is just as beasty
anirudhks
after holding back for long time itchy hands :p shifted to CM13 rom , so far very smooth and good .. not really missing the MIUI , using app cloner for the multiple version of apps.
jimbo73
There is one listing on lazada for the 3gb/32gb model going for $309. After factoring in discount code($20-25 max off depending on bank specific) + shopback cashback(2 or 4% depending on whether you are new or returning lazada buyer) + credit card rebates if any, the final cost of the phone would be around $270+.
Thanks for the tip... bought one set at 290. With global rom and playstore installed. Working perfectly. very happy with the purchase
maxlovely
There is no official global rom for mi max yet. You probably can't receive new OTA update with this global rom.
tofubean
I got from same seller. Its custom rom with ads, can see ads from screensaver. The mobomarket and some horse browser cannot delete away. Dunno got malware or not... I flashed with china stable rom immediately.
maxlovely
Make sure your phone log into the same mi account which you apply for unlocking bootloader before you try to unlock with unlocking app.
After unlock bootloader successfully, I advise to log out the mi account from your phone.
Those with unlocking granted, do you have issue about device cannot be verified while using pc unlocking app?
What now?
Do you really lose fingerprint scanning/unlock after unlocking?
Bobby Goh
I think he's more interested in the identity of the seller... So as to avoid buying from him.
buzbuz
Yup, approval sms received, phone was login, and so did the unlock app, but still dark to verify after fee attempts, thanks anyway. Shall wait couple days. Just wanna root.
pilico
Does anyone know how to disable the auto screen off and doesnt affect the lockscreen Screen.
the only setting i found is from lockscreen tab. Which affects both locked screen and after lock screen (same timing).
I wish to set lockscreen screen off after 10-15 sec and after unlocking the phone, never off screen.
