Xiaomi Mi Max
anirudhks
Think this is only for 32gb only.
no the XDA has the modified files for the 64Gb as well , you will have to use the kernel auditor app to enable the core 7and core 8 after booting if you want all the 8 cores of the CPU to run , but liking it a lot with clean android and performance.
touchme
What must I do to enable mx/bs player to read/play media files from usb-otg?. Needs root? Playing from ES, do not give mx/bs options.
Apparently the players can't detect xm otg directory structure (no issue with other phones). Funny thing, storage settings do not show usb storage device too, but ES does.
tech_oasis
Once mi send msg say unlock means unlock right? no additional steps required.
Tried to flash global rom but encountered 'The system cannot find the file specified.(0x80070002)'
Attempted to resolve with thread below but can't. Anyone can help or succeed
http://en.miui.com/thread-91415-1-1.html
Thanks
CrucifyMyLove
my flash tool shows flash successful
but my phone stuck in booting screen bery long liao
omg omg~~
maxlovely
I think Mi Max can flash global rom using edl method but I don't have a 32gb mi max to try.
Previously I flash my 64gb using edl method and is working fine.
CrucifyMyLove
Yay! Manage to flash
Surprisingly, old apps still there
Audiology93
just applied for unlock. i can't even go to recovery mode(pwr + vol up) due to the custom "global" rom preloaded by ziming global.
zeroflame
unlocked bootloader and flash via fastboot method successful!
Register to unlock bootloader
http://en.miui.com/unlock/
PC software to unlock once received sms it is ready
http://obigota.d.miui.com/miflashunlock/MiFlashUnlock_1.1.0317.1_en.zip
Fastboot rom
http://bigota.d.miui.com/6.7.5/hydr....5_20160523.0000.23_6.0_global_e315d20870.tgz
MI Flash tool
http://bigota.d.miui.com/tools/MiPhone20151028.exe
To get into fastboot(bootloader) mode :
Turn off your device.
Press the Power button and Volume - button at the same time to enter bootloader mode
a_keong
Fastboot rom
MI Flash tool
Hi
Can check which method to use for keeping all my data before flashing to MIUI8. Thanks
