Xiaomi Mi Note
KlavierX
Tomorrow going drive to kasia and buy cannot wait haha $25 nvm support kasia =x
avsquare
Xiaomi online store sells tpu case for $1 and smart flip case for $12 or 13.99.
Not keen in those kind of cases tho, looking for better designs like for example:
For-Xiaomi-Mi-Note-Pro-case-New-High-quality-silicone-protective-case-cover-for-Xiaomi-Mi.jpg
Devilsire
am using the 1st one, damage $25 bought from carousell. i wld say its much nicer than the clear tpu.
As for tempered glass, i was told by the seller there's currently 2 types. One too big due to curved screen leading to dusts trapped at edges & bubbles popping.
The other too small not covering the full screen. Thus recommended to just stick to the normal original sp :o
spigen style casing & soft tpu i bought today all ready for phone and....
KNS ARAMEX! :(
1st time kena aramex, anyone know if they deliver on wkend?
Sent from Xiaomi MI NOTE LTE using GAGT
kenzon
Look jin chio .. Got In white?
Sent from celestial being using GAGT
kelvinti
I'm using note pro now. Not recommended due to overheating issue of SD810.
Yeah! SD810 is known for that.
I guess that Xiaomi has not or rather has no intention to fix it in their Pro model.
avsquare
Sian went around to mobile shops locally, seems that they don't import Mi Note cases, even Mi4i cases are mediocre (mainly transparent TPU/jelly cases).
Trying to order this from Carousell instead. Nillkin cases are pretty nice, used it before.
https://carousell.com/p/25235157/
hksin
export set hah? what's the differet with mi note? in size or spec only?
Got direct from mi china. note and note pro are same externally. Difference are CPU SD801 vs SD810, ram 3GB vs 4GB, screen full HD vs qhd.
kenzon
