Xiaomi Mi Note
mac_oasis
Yup... Mi note certainly is best value ever.... And battery life seriously is good especially since it is dual standby sim!!
One thing is I'm permanently on "performance" mode... Cos balanced mode I feel a bit laggy do typing.
I agree, manage to download and try MIUI 7 and also stick lollipop but went back to MIUI7.
Battery life is extremely good. however point to note, better to wipe out data clean then upgrade to MIUI 7 else like what mosprokett mention there is on the timeout download thingy from the chinese MI app from MIUI 7.
mosprockett
One more bug is my WhatsApp notifications are delayed or don't appear..... After awhile I realize is not a bug but rather a function of miui default security profile...
To enable WhatsApp notifications you need to add app to auto start permissions within security app...
I guess this strict security profiles is also what makes miui battery life so powerful
x09a_justice
facing the same problem... but it cant be solved even with the permission thing in security ....
must send feedback to xiaomi
BERSERK1980
An annoying thing i noticed is that the phone seems to be sending or receiving data on its own despite me restricting everything on my phone. I always noticrd that the network traffic for my 4G data is quite high. Sometimes reach near 100mb per day without me using much.
mosprockett
One more thing...
Inside the task manager (left side menu buttkn) swipe down on WhatsApp icon it will remain "locked", so when clear apps ram it won't get cleared.... Just slide down on the icon, don't press and hold. There will be a mini lock icon appears on top of the WhatsApp icon.
mosprockett
Same thing happen to me. Go to installed apps and clear data / cache for the downloads app and download manager.. That solved it for me.
BERSERK1980
Will try it. Thanks bro! Appreciate the advice. Already drained me of my data plan liao.
rharish_21
Lazada is selling the local manufacturer warranty set from Novel Communication for 499...
mosprockett
Thanks for your good tips... still now working =(( checked miui fourm and we are not alone
Q
Ok another propbelm.... My WhatsApp notifications not working ONLY When phone screen off... If phone screen on its immediate...
UPDATE:
Whatsapp notifcation only got issue if on WIFI mode. On mobile data its instant.
UPDATE 2:
Problem solved! Go to wifi, advanced settings and disable optimize wifi to minimize batt usae.
jaxel80
miui 7
sorry if tis is a stupid question, but i really dunno.
is miui the samsung equivalent of touch wiz? meaning to say miui is jus a UI(user interface)
I am confuse cos under the phone software it says miui n not lollipop or any other android software name.....its seems to be miui is also an OS running on xiaomi
Oinkize
Yes. Miui is just another launcher. Mi note is still on kitkat.
emgee
Considering Mi Note or OnePlus2 as my next big screen dual sim phone. Which phone more worth to buy? Tried Mi4i before and my experience was not particularly pleasant due to overheat, lag and the bug on SwiftKey keyboard
Oinkize
On paper and pricing, one plus two is better...
Seifer28
using mi note pro now....
not very impressed with Oneplus2 Oxygen OS.... lots of bugs and don't know when they can fix
http://mall.shopee.sg/item/#shopid=13516&itemid=262647
Checkout with hardware20 voucher code still can get another $20 off.... super good price now
Kent110285
Notice something today morning while I was awake to charge Hp. I off the set and connected to charger as usual. When I woke up 4 hours later is only at 66%, hence I on the Hp back n continue to charge and now it shoot up to 80plus % in less den 30 mins that I have awaken. Anyone have this issue?
hksin
Mi note pro still got heating issues?
Using Mi Note pro for past few weeks with miui 7. Overheating issue have significantly improved over past few weekly release. Battery life is also very good and can definitely last more than 1 day on moderate use.
