Xiaomi Mi Note
shawniiex
Notice something today morning while I was awake to charge Hp. I off the set and connected to charger as usual. When I woke up 4 hours later is only at 66%, hence I on the Hp back n continue to charge and now it shoot up to 80plus % in less den 30 mins that I have awaken. Anyone have this issue?
Probably a one off thing. Why do you off and charge though?
Just leave it on? Lol.
mosprockett
After a week of using miui7,
I can confirm battery life is amazing. It TOTAlly optimizes battery usage when screen is off. Today since disconnecting charger at Abt 9am, still 89pct (didn't use much la) but still darn good!
Problem is still got bugs with delayed notifications and today my gps can't log on...
I might go back to miui6 and wait 'till official version released.
x09a_justice
going back to miui 6 tonight, battery drainage (after switching off the battery optimization for whatsapp to work) sucks. the battery drain like a boss espeically at bad reception areas (1 afternoon nap 2 hours drain 8 %)
TorkCrap
Hi guys, does anyone here use mobile phones extensively as a portable music player?
How does mi note perform in this aspect?
I have seen mixed user reviews regarding the Hifi feature of this phone.
JuXn5566
The sound quality is great, one of the best sounding phone after Vivo. However, you have to tahan the built-in MIUI music player . Only use MIUI player then able to get the hifi effect. MIUI player can support flac but is not as user friendly and feature rich as 3rd party one.
Sent from Xiaomi MI NOTE LTE using GAGT
TorkCrap
Hello Juxn. Do you mean that the hifi feature can only be activated and effected on the miui player? Meaning that third party players or streaming services like Spotify will not be able to tap on the hifi components?
In the case, how would you compare the audio quality of the mi note without the hifi mode, against other phones? Does it still stand out?
JuXn5566
Yup. Spotify will not be able to have hifi. Without using MIUI player, it will stand out in term of loudness as the raw power of the soundchip is there. However, untuned, so it sounds pretty average, still better than most android phones.
mosprockett
Another new thing for those running miui7:
Go to battery and disable manage apps battery usage.
Solves a lot of buggy issues such as whatsapp notification and also my Google maps cannot get lock.
Battery life not really impacted much
Zantesuken
need urgent help here.
while upgrading to miui7 my mi note pro stuck at 99% and now is dead. im trying to restore it from fastboot but xiaomi server is being a b1tch and has horrendous download speed. just trying my luck here if anyone has fastboot ROM for MI NOTE PRO..
thanks alot. please drop me a pm.. urgent
rharish_21
Hi,
Try to add a character 'o' just after http:// in the url and download
rharish_21
Bros here .. just got a new mi note .. and joined the ship :) new to xiaomi devices infact my first can anyone help how to root n get china miui 7 rom ?
Sent from Samsung SM-N920I using GAGT
Hi its very simple..
Just download the China Developer Rom from the following URL http://obigota.d.miui.com/5.9.10/miui_MINote_5.9.10_1cba59d072_4.4.zip
Copy it under root folder of your phone.
Go to Updater app in the phone press the ... menu button and choose update file
browse for the downloaded file and click ok..
It will install the rom and ask you to reboot.
Thats it, now you're with China Miui 7 beta rom
if you want root, go to the security app in the phone, then to permissions. root is already built in the beta roms.
Do note that you need to install the google services through an apk. Unfortunately i dont have the link for it.. so google it.
hope i was helpful with the wall of text.. :s13:
anirudhks
super thanks a lot , yes everything worked ... :D thanks again
anirudhks
Glad I could be useful.. enjoy your device
need another help :) i have my primary sim which is data enabled a non sim and the 2nd sim is a micro so i have put the sims accordingly on the sim tray
however I am not able to enable 4g data on the 2nd sim which is the nano sim
please , i can see and set the apn but data is not appearing on the display not able to browse ..
mosprockett
Did you toggle the data from the correct Sim in the menu?
This phone does not support simultaneous 4g connection. U have to choose which one Sim you want the connection to come from.
mosprockett
Anybody using mi note pro who also used mi note (normal)?
Currently my mi note doing quite well with miui7 but itchy to try how a mi note pro feels also..
Is it super duper speedy?
