Xiaomi Mi Note
napster79
Anybody using mi note pro who also used mi note (normal)?
Currently my mi note doing quite well with miui7 but itchy to try how a mi note pro feels also..
Is it super duper speedy?
Haha.. Great mind thinks alike :D I also backside itchy, thinking of changing.. :spin:
pawn_king
Price difference 20%-25%, may not be worth it.
Pro price even higher than oneplus 2, even though specs are similar and pro launched for a few months already.
probably should wait for the Mi5 instead?
mosprockett
Hmm good idea... I was thinking to try one plus, but I have come to really enjoy miui7... It's really super quick and good Batt life!
mosprockett
Is it only my phone or does all the Xiaomi apps not able to to load the data properly, EG themes, music etc.
Always seem to have problem loading... My other apps all fine.
napster79
Mine too.. It seems that the xiaomi server cannot handle the high traffic..:s22:
BERSERK1980
Dont do it, you will regret it. Mi note itself is a fine phone but the pro version is a mess. Overheating, throttling, performance slow down and terrible battery life. No need to thank me.
unintended
Came in here looking for this answer. I need a replacement phone but not sure whether to recontract since im still on 12gb. But thought of 500+ for xiaomi is quite pricey. Then wonder if pro is coming should i wait..rather than get note now and suddenly xiaomi sg announce they wanna bring in
amazingone
Pro not coming anytime soon, they're planning for Redmi Note 2 now. :)
Sent from my Rice phone using GAGT
mosprockett
Ok bro thx anyway :)
Just updated to the latest weekly miui7 build and as speedy as ever... Quite fast even considering mi note processor isn't the top of the line.
I don't even bother with stock google rom anymore...
mosprockett
One tip for those looking to keep their phone running speedy:
Schedule a auto reboot every early morning, EG power off 6.55am power on 7.00am
Your phone will be blazing fast the moment u wake up everyday...
U can go security -> BATTERY to do this scheduling...
anirudhks
Did you toggle the data from the correct Sim in the menu?
This phone does not support simultaneous 4g connection. U have to choose which one Sim you want the connection to come from.
thanks bro yes now set to all 2nd sim , still not used to miui.. so many difference to normal android
anirudhks
that is a good option :) thanks
KlavierX
thanks for useful settings on the auto sleep and wake thing now my phone really faster
sleepyjoy
Camera manual mode
Hi guys,
I went to the SingTel, JCube today to have a test and feel of the Mi Note.
When I switched to Manual mode in the Camera app, the screen started to have red pixels showing up where there was no red in the view. (Eg: I am pointing at a black cable on white table, the black cable would have a red highlighted glow around it caused by these red pixels.)
I asked the salesman if this was suppose to happen, he said no. So I said, maybe it's because I turned on Manual. After I turned it off, the red pixels disappear. Then he said, "Oh, it's because you turned on Manual." :s11:
Is this is a normal occurrence?
It's because of the camera and specs that I am considering the Mi Note. Should I go for the G4 instead? :slant:
Audiology93
Hi guys,
Camera wise, mi note confirm lose to G4. Specs also. Only thing that the mi note is better is the build quality.
shawniiex
Hi guys,
Definitely not normal dude. Why would any camera have such an effect.
JuXn5566
Hi guys,
It's a feature called focus peaking. The red will highlight the focus for you, meaning to say the more red on an object mean more focus the camera on that object. This is useful in manual mode which often found only in DSLR
Sent from Xiaomi MI NOTE LTE using GAGT
