Xiaomi Mi Note
jetstream819
Ok finally got my hands on mi note. Overall very satisfied! Batt life is good. Fast and responsive. I find this even better than samsung firmware. So much less clutter than samsung phone.
Only cons is casing availability are so limited. Looking for some protective casing but can't really find any shop carrying them. Only those basic jelly type.
Look for seller named "Revelion" on qoo10. It's the only store that offers extensive case/covers for Mi Note in SG afaik. Bought one from there. Also, can consider HeadCase design too (only back cover but with many many interesting designs)
caterham7
xiaomi singapore has some limited choices
http://store.mi.com/sg/item/3153000003
http://store.mi.com/sg/item/3153000002
xiaomi tmall [china] has more choices; can ship to singapore
https://xiaomi.world.tmall.com/cate...BC%FE&catName=%D0%A1%C3%D7Note%C5%E4%BC%FE#bd
arcaninx
I cant download Bloomberg LP app and Mytransport@sg
Keeps saying "this item is not compatiable with this device".
Does anyone face this issue?
Oinkize
Yes. Mytransport has this issue on mi note.
s1mple
yes, LTA sucks, it's just simple config changes on google play store setting, but yet they don't do it. I email them 2 months ago, but no reply and changes yet.
Anyway you can download the apk using www.onyxbits.de/raccoon and install it manually
anirudhks
anybody knows where to get back screen protector or a skin for the back of the mi note , I want to use naked but scared glass back scratch .. also can we replace back cover like bamboo ? couldnt find any local seller all the sellers are china or aliexpress
yodafone
Yeah. Don't think anyone will sell here. Buy from Taobao cheaper. Use a sucker to pull up the cover near the camera carefully until it detaches, then use spudger to release the rest of the back cover. If you are patient it's not too difficult.
jetstream819
Using onw now. Feels great.
http://shopee.sg/jetrading/1657073
geckoSG
It is at a position where your thumb reaches it easily.
Better position than being on top.
Anyway i have never encountered any data lost due to power button being placed there.
Not for samsung, sony, iphone nor xiao mi...
What was the exact reason that your phone hard resetted itself?
No idea how did phone goes in android screen n loses all data. U hold phone with right hand while i hold mine with left, tats why my long fingers r generally pressing the power buttons all the time
anirudhks
thanks again ,
bought it today and pasted , looks n feel good :)
and for 4 bucks its super deal
anirudhks
hi all , all though i am thourougly enjoying my Mi note , hands are a little itchy for the note pro .. would u guys recomend to upgrade?
Oinkize
No point. No local support.
I changed to opt, it's very hot and battery life very bad add compared to mi note with the same usage.
