Xiaomi Mi Note
BERSERK1980
Damn jialat. Cant download miui 7. Freaking servers are slow as hell and keeps getting dc after a few percent.
JuXn5566
Skip the latest version of china dev rom, it got vibration bug where vibration is set to max and no way to reduce it.
bkling1
Not sure this question has been answered. Just got a set of mi note for my mother. However, Even I set the font size to the largest, the font size is still pathetically small. When type message I can hardly see clearly and how to expect old people to read it comfortably.
Any way to solve the problem ? I tried to install some apk but it enlarge the system font but when come to other application, it over do it till outside the screen.
sleepyjoy
It's a feature called focus peaking. The red will highlight the focus for you, meaning to say the more red on an object mean more focus the camera on that object. This is useful in manual mode which often found only in DSLR
Oooh.. so this is focus peaking! Read about it somewhere in this thread, but I've not seen it in action before. Thanks for clarifying! :)
JuXn5566
Install MIUI7 china Dev rom then use the XXL font.
Sent from Xiaomi MI NOTE LTE using GAGT
gbpdem
not sure if right place to ask
am using the Note Pro,
is there any way to disable the Mi Store default pls ?
i understand that Mi Store cannot be removed
as it will cause problems
aogiliu
Go google play store and download LBE安全大师(免root),see if you can solve the problem.
gbpdem
thanks bro for the useful app !
i am not looking to uninstall the Mi Store
as i have read that it will result in a boot loop
when the phone does an update subsequently
this is my first time playing with a XiaoMi handset
and i just want to disable it/set it to non-default
but it looks like i am unable to do so
geckoSG
I really hate where the buttons r located, easily trigger turn off, turn on when holding phone with left hand.
mosprockett
Agreed. Power button I find will be pressed easily when I put phone in bag... And worst is pressing power button for long period will reboot phone by default.
mehmeh91
is this phone worth getting ? i am quite interested due to the hi fi sound output by the audio jack. Has anyone compare with their mp3 or with other phone b4?
Thanks :s12::s12::s12:
caterham7
You can try at xiaomi service centre at Clarke quay central. Bring a micro usb thumbdrive, then can play your own mp3 files. Remember to turn on the hifi setting and use the xiaomi music app
miltonwkw
Anyone knows of a reliable and inexpensive repair centre to write imei for the mi note pro? I lost the imei while flashing a rom. :eek:
cyberian
What is 双网通 and 全网通?
Anyone know what is the different between 双网通 and 全网通?
geckoSG
And pls be careful, you might even set it some sort of reset as my data was recently cleared when it reboots. One of the worst designed phone ever.
