Mi note better than opt ah? Hot as in when use will hot?No point. No local support.
I changed to opt, it's very hot and battery life very bad add compared to mi note with the same usage.
Sent from Samsung SM-N920I using GAGT
When use hot, s810 notorious for overheating easily.
Speed wise frankly speaking not much difference...
oic. i used z3+ also scared by the s810.
anyway does mi note come with many useless apps?
put an ' o ' before the bigota word of the link.dont even know how to download chinese dev rom. super slow download speed and download disconnected halfway
This model is not.compatibe with a number of apps like bloomberg and mytransport@sg
Anyone else facing this issue?
is it possible to flash mi note to vanila android rom?
currently using nexus5, on marshmallow
like to, so far
just the nexus5 batt sux, need dual sim slot
oneplus 2 seems nice, but mi note spec nicer, especially the hi-fi DAC chip
Cannot connect to Singtel Wifi at all at the shopping mall.
anyone having same issue connecting using Mi Note, on Combo plan?
anyone got the solution, appreciate it
thanks
updated to v7.
still kitkat 4.4
battery life is amazing
have u all tried this?i have the same problem with my redmi note 2 too, cant connect to singtel wifi at mrt station etc![]()
Not lollipop? A bit disappointing that xiaomi signature phone didn't get it![]()
