Xiaomi MiTV2 help
BlueCloud85
lijunyi26
So guys, I have been reading a couple of pages now. Was wondering which will you choose?
TV3 or TV3s given the fact that TV3 comes with all the electronice components in the sound bar and TV3s does not.
Like... TV3s seems newer but the fussfree set seems like TV3 as we can just change the sound bar if anything goes wrong.
Also I read afew post on digital antenna. Was wondering is there a need for new BTO? Or we still need to buy? Cos I'm really not sure how the DVBT2 works.
cscs3
ckling
3s 65inch and above is separate one. Dvbt2 box is quite cheap, it is just a box connect to HDMI, add additional antenna if signal not strong enough
lijunyi26
gnixer
My guess is that the price range for the Mi TV 3S 65" with subwoofer and surround speakers would be about $2,299 with 1yr warranty.
If it is at that price, would you still buy this?
if they inflate the price x times higher than bo hua liao.
i rather buy from oversea then repair by them locally unless repair too high or beyond economic repair then will dump the damn tv :s13:
lijunyi26
icic.. Guess I'll TB them haha..
Still deciding to get 55" Mitv 3 or 65" Mitv 3s for my 3rm BTO as our living room is pretty small. :(
cscs3
Not all DVBT2 box works the same. Problem with those cheap box is firmware support.
Also, when you are on seperate box. This means you need multiple temote control and power point, external wiring etc.
lijunyi26
Was thinking can i buy 1 dvbt2 box for 1 tv and 2 antenna for the rest to receive the box's signal?
i1magic
You see which one more value for $$ lor. I am using the Mi TV 2 55", which is quite big. But my living room can put probably up to 80"!! LOL!
MUST buy the Mi TV subwoofer, si bei powerful!
