Xiaomi Mix Fold 2
saj282
It has one known major advantage over ZFold4 — support of Dolby Vision, on top of HDR+.
Can someone confirm on the following as well?
1) Does it support AptX HD?
2) Does it support AptX Adaptive?
3) Does it support/compatible with Microsoft Intune? (Work requirements)
The first 2 are important to those using latest gen high-end wireless earbuds and headsets. such as those from Sennheiser and B&W. Apparentl, Samsung did not enable them in ZFold products despite that the chipset support them..
clyp1973
I'm using 12S ultra. Everything works except intune whereby most times you need to click Company Portal before you launch outlook.
I have set all permission but still the same
saj282
Thanks! Then it is no go.. looks like have to wait for Pixel Fold.
Computeron
Saw shopee got fold 2 under local warranty... is that genuine?
is seller own warranty...
if ur set has any problem, seller will say, its software problem, pls wait for upcoming patch..that will take months..
they wil just push here n there till ur 12mths warranty expires.
if hardware problem, will cost u a bomb.... if sent back to china, u aga aga 1- 2 mth no phone.
rootz
I recall the key reason why people won't buy it locally is due to lack of support and maintenance issue if spoilt. Imagine a 2k paper weight.
So not likely to gain trackion locally.
wildpig8
To date everything works nicely...:cool:
Installed google play store, WhatsApp, WeChat, banking apps... all working fine.
A few website listed under screen finger scanner, but i just cant find it anywhere in the settings.
cueball1981
So far great experience on the mix2.. however anyone can install chrome? Not a real deal breaker because i still can use Chrome beta.
dorabee
Any inconvenience in terms of the inner display having no camera?
Where do you guys get it from? Online platforms or ship directly from Tmall?
year2013
I think its better to hold for Global release, spending $2000 for Folding device is risky!
I used Z Fold 2 and 3, for both got problem with inner display within 12 months, luckily its covered under warranty.
Tyrael
DBS/POSB banking apps, Google Pay NFC, all working well?
