Xiaomi Redmi Note 2
halocast
quite disappointed they choose to bring in a older model. :(
shld at least be prime..32gb.
if they release redmi note 2 pro.. in december.
will be total sucker punch.
clay9477
Lol the rumours flow faster than water. Now on 11 Nov in China dunno is Mi5 or Redmi Note 2 Pro or both.
aogiliu
Any diff between local and export set besides warranty?
I used my prime version one month+, if you wait for local prime set, maybe wait for one month+. The diff is you buy early, you use early.
Sent from Xiaomi REDMI NOTE 2 using GAGT
lockks
Local set and China set, any difference? But for updates of software, will there be any problem?
Devilsire
no significant differences other than warranty. ROMs & Softwares like gapps can be installed
cscs3
Local set with local warranty and global rom which include google play etc.
Hopefully there is no hardware different.
Ps. At least the charger is different.
kazuki666
China set no google play?
All china phones by default do not have any google apps de. Google Play, Google Maps, Google Chrome, Google Search etc etc. If you bring your non-China phones like Apple, Samsung etc, you will know none of the google apps work there de. Unless you vpn. :p
Ok, the most impt difference for China domestic sets and Singapore local sets is the OS. China sets get the China rom, while Singapore sets get the global or Singapore rom. So unless you die die want to get the 32gb Prime which Singapore does not sell currently, then be mentally prepared to know your China phone. Back then when I got my Prime, it was my first time getting China phones. It took me a couple of days of testing and asking in forums before I find out the best and correct way to do it.
kazuki666
So far they have leaked 2 products for tomorrow 11.11 event.
  • 2000mAh powerbank
  • Mi band 1s
But they are really keeping secret what phone it will hit tomorrow... I suspect should be Mi5 le. Can't be Redmi Note 2 Pro
aogiliu
  • 2000mAh powerbank
  • Mi band 1s
Can not be mi5. SD820 hasnt released. The so-called secret phone is Redmi 2A which price dropped to RMB499. You see xiaomi Sino Weibo then you can see it.
amazingone
there's one more awaiting for crowdfunding ~
Sent from my Rice phone using GAGT
