Xiaomi Redmi Note 2
aaatop
Just received my RM N2 last week. It's on stable rom 7080, it has a new update, should I go ahead or leave it as it is?
s-ghost
High Honorary Member
got a long question here:
rmn2 have dual sim but i have been on one all along. recently i got a mobile broadband sim card, thought of using the rmn2 as a mifi. so let's say i put both sim card in, how do i distribute the usage, like SIM 1 is used for calls/msg etc while SIM 2 is use as hotspot and data?
if based on above scenario, does it mean SIM 1 data won't be used at all since SIM 2 is dedicated as the date giver?
hope not too confusing haha...thanks :o
aaatop
I'm doing exactly that.
Sim 1 set for calls only.
Sim 2 set for Internet only.
U can preset data limit alert and quota for sim 2.
s-ghost
is not possible to say
SIM 1 - calls/msg/mobile data
SIM 2 - solely as a hotspot for tablet
can't right?
Tok Kong
Haha software wise we be supported far longer than Redmi Note 3. There is almost i can't remember how many million of Redmi Note 2 sold, their aim was 10million but of course didn't hit but somewhere around 3~4mil. Like Redmi 1S super long support because user database too big.
XD go back Redmi Note 3 thread, dont come taunt us here. Haha.
this is a important info. thanks.
Bryson
After upgrade to Miui 7.1.1. Whatsapp message delay problem returned.
Did you enable the autostart permission for whatsapp in the "security" app? My whatsapp seems to be fine.
Btw, even with latest dev global rom, my original pebble watch still can't seem to notify whatsapp messages.. :(
clay9477
can't right?
Hi, yes you can use mobile data for both. But like others have said, if you want to use internet on both sim cards, you need to go into SIM cards & mobile networks, set the default settings for the respective sim that you want internet on, and the other one to dial. For eg, if you want SIM1 call set to dial and SIM 2 can be for mobile hotspot set to internet. But if you want to use SIM1 mobile, you need to change the default for SIM2 to dial and for SIM1 to internet.
Also, good to use the security app, then from there use the data usage manager to set network data limit as well as restrict the apps that can use data. Very good management system.
Cheers.
clay9477
Good to drop a mail to pebble support see what they can help.
limpingsim98
Yes. Is enable. If WiFi is disable. It seem to work fine just with mobile network.
Bryson
I got my pebble working again, fingers cross if there's any problem again. Enabled every permission except for the WiFi option in the permission manager. So far no problems yet.
Also, I just tested, with Bluetooth connected to the pebble watch and data switched on throughout the night, I received a number of Facebook and WhatsApp notification and drop by 8% in 6 hrs, is it an average drop of battery drain or massive? Sorry for asking so much. Cheers!
Sent from Xiaomi REDMI NOTE 2 using GAGT
hyper_megaman
can't right?
What do you mean by Sim 2 hotspot?
Do you mean Sim 2 also running mobile data, and used exclusively for a hotspot?
NicoNicoNii
Bluetooth on. Very normal as your phone is communicating with your pebble
Sent from Xiaomi REDMI NOTE 3 using GAGT
clay9477
For those who complain poor battery life, can try charging your phone overnight. Been doing that recently and noticed battery charge is better. Used to only charge 2hrs, hit 100% then plug out but who cares, just buy another battery if the charge dies.
Nakedtoes
Just got this phone for my mum.. Very nice phone. Very surprise very light weight and slim. Screen is very sharp also. Can ir aircon and teebee.. Lol
