Xiaomi Redmi Note 2
i1magic
I would have gotten Redmi Note 2 if not because of the camera.
Camera no good?
The camera quality is ok. Probably similar to Note 3. If you doesn't zoom in, the pictures are ok.
If you put the picture side by side with Note 4's picture, can see the difference liao.
But I don't expect it to have the same picture quality as Note 4 lah.
i1magic
cscs3
Have to agree with you on that also.
Few reason why I still stick to Note 4 :
1. S-Pen
2. Camera
3. Micro SD card slot (Redmi Note 2 also have)
4. Removable battery (Redmi Note 2 also have)
Same here. Plus almost no bug for my day to day usage.
Miui quality is getting worse each day.
Oinkize
Note 2 camera > Note 3 > Note 4
Battery life Note 3 > Note 2 > Note 4
cscs3
Can't really compare a budget mid performance phone to a high end phone.. You get for what you pay..
Sent from LGE LG-H815 using GAGT
This type of statement is not always true. It all depend on which function you are comparing and also against what is been advertised with the product (ie specification vs real use). Also, how current is the product.
Samsunt Note 4 for example is a 1.5 years old design. Xiaomi Note 2 is only 3-4 months old.
If everyone justify by you get what you paid. You are giving the maker to have a chance to sell you a product that is not working according to advertised specification.
kazuki666
faint. I was too unhappy how the 6.2.2 is sapping up the ram, so i hands itchy go downgrade to 6.1.8 using Recovery Update method. BANG! Downgrade was no problem, BUT it keeps popping up the sql error non stop. I cannot backup or even upgrade back using recovery update method already. No choice had to factory reset. The most sian thing is that my data backup was 2 months ago... :'(
luei74
Should use fastboot plus Miflash instead. Pretty straight forward and fast..
Sent from ATXMNote2 smart phone jin hoh yong. using GAGT
touchme
funny that xiaomi sg so not sell spare battery and its dock by themselves.
Have to get 3rd party about US$10 for both.
kazuki666
This is because even China Xiaomi has not release official spare battery and dock as of date. Though its weird why they created removable battery design, but didn't sell the battery as spare... Not sure is it they pushed out Redmi Note 3 too fast until they decided to give up on Redmi Note 2... :(
zee-ah
Does the white cover get yellow easily? And should I get the back cover from the store as well? Or are there any better and more worth it cover elsewhere? Thanks.
luei74
Rebooted after 1k plus hours of usage... is there any good apps to free up the ram?
