Xiaomi Redmi Note 3
sbladerz
haha true enough. Phone only 299. just that, I had higher expectations because of the rave reviews.
your photo definitely looked better than what I had took.
likewise, I have upgraded mine to the 7.3.2 firmware.
JivBunny
export set, octa core is not the snapdragon version, it's the MTK version.
Actually if you don't use the phone for gaming, the MediaTek chip is not that bad altogether.
Charging is a bit long though because i think the MTK chip don't support quick charge
ZhuTou!
As long the focus is locked
The pic will look nicer
U can scroll back few pages look at kelvinti photo
android
Anybody having problems with screen not turning on when receiving WhatsApp or SMS? The notification light came on but screen did not turn on...
amazingone
Note the date: 31st May, 12noon~
Sent from my Rice phone using GAGT
Nakedtoes
Yah .... do face that issue too. Any solution?
I dun get it.. Sometime I remove case put back ok.. Funny is when under sun or hot sun the light Meter value is negative thus screen dimmed. I shine torch the reading is higher no negative.
