Xiaomi Redmi Note 3
amazingone
Infraction has been given to ladytoto90 for continuous "advertising".
Yep. Have seen reports of it last month and gave the benefit of doubt to monitor - due to it being 1 - 2 instances - which could indicate a forumer who had a great experience, but this is probably alittle too much with almost every post being an advertisement for that particular outlet.
Thanks mod for the attention. :)
Oinkize
Folks,
Side track a bit about WiFi. Those who have 2 access points (2 WiFI router) at home.
Do you use any 3rd party Auto WiFi switch app to let the phone auto-switch to whichever has stronger WiFi signal? :s11:
Nope. Let the phone decide by itself...
batniss
I'm also waiting for Note 7 as my high end new phone while the RN3 serves me well now and can keep as a backup or secondary phone when I buy the Note 7...
but the price is something that might put me off. shall see how it goes.
batniss
Folks,
it should be performed automatically if you have configured your router correctly.
kelvinti
Mi max is cheaper than rmn3 now :eek:
Wow! Unbelievable!
I still want a local set if I want to buy Mi Max... Save all the troubles from China rom and warranty...
Anyway, I will not buy Mi Max lah. Just too big..
xiaoyuer89
the signal range is not as good as any other phones which i've experienced.
I believe i have highlighted this before as well
i see.. just wondering if is hardware or software prob... if software problem hope xiaomi solves it quick
Kitaro9202
Wifi issues anyone? Cant seem to receive it well at home now but my zenfone2 can
My xiaomi wifi seem better den my sony z2 leh and asus zenfone
Both at toilet no signal but xiaomi have
Btw i notice my xiaomi battery recently drain fast SOT 2HR + battery low
kelvinti
< Update >
OK. My WiFi auto switch is back to instant switching now in the last 6 hours. :)
I guess it was due to network issue from StarHub that cause my routers to be unstable for the past 48 hours...
Thanks.
kelvinti
Hmmm... Check any rough apps that consume large amount of juice in the foreground and background?
xiaoyuer89
apparantly the signal is stronger but the wifi keeps getting disrupted for my xiaomi. gets connected den disconnected but ok with my zenfone so far
kopi22
No problem with my 2.4GHz WIFI connection so far. Maybe because I have only 1 band enabled. On the contrary, my router will act weird when 2 bands are enabled. The free DLink router from Starhub...... :s22:
kelvinti
Yeah. Super duper expensive.
My options are opened to, at least, a 5.7" or 5.8" screen size with good camera in low light / night.
Let's see what are coming this summer besides Note 7..
