Xiaomi Redmi Note 3
Intrinion
Senior Moderator
Senior Moderator
Was at Funan Challenger earlier this evening.
The 32GB, 3GB version is out of stock.
Believe that the 16GB, 2GB version is still in stock - no out of stock label :p
Intrinion
Senior Moderator
Senior Moderator
You should get one asap. As for the price, it depends on your luck whether you can get a cheaper offer from any sellers.
At just $299, this speedy phone is bo bei chao... Worth every cents even you just use 1 sim card. The 2nd sim slot can be used for sd card. :)
:) Good for travelling as well!
1 local sim and 1 default sim.
Intrinion
Senior Moderator
Senior Moderator
On the Mi website, it states that
4G dual SIM support allows you to access 4G on either SIM slot. Simply customize which card you want to dial or use data from in Settings.
Would like to check on the 4G dual sim capabilities of the phone.
So from my understanding of the above sentence, it's 4G on either slot - so I can get 4G on either slot 1 or 2,
If I have 2 x 4G sim cards inserted - I will get 1 x 2G and 1 x 4G?
Just Me
Battery life seems to have improved with the latest update. With 14% remaining
Sent from Jiak Liow Bi phone using GAGT
Intrinion
Senior Moderator
Senior Moderator
While reading up on the dual sim slot.
Found this interesting mod where one could use both sims as well as micro sd simultaneously.
Procedure looks tedious.
Not recommended to try.
kelvinti
Correct. 4G-2G only. Not 4G-3G even though both are 4G sim cards.
kelvinti
Ya. Better don't try. Else, after a while, cards stuck inside and damaged the slot tray... Big trouble.
hornbox
I am bored of my xiaomi redmi note 3 already. The 32gb one which you all say no stock. Shall post in marketplace liao...
DigDub
8mobile is chop carrot head one. and the price they display excludes gst...
hornbox
Nope not getting the One plus 3. I used the one plus 2 but i didnt like it.
Shall see if it has gained back the charm as one plus one.
I have set aside cash for Samsung Note 6 or 7. And also iphone 7 plus.
But interim, im happy with my huawei p9
