Xiaomi Redmi Note 3
lewissac
Yes. Once you are on global ROM all Google apps will be present.
Any slot can be 4g enabled. You will just need to select which sim to be the internet sim.
Thanks for the advice. Was asking this because I don't wanna spend $37.00 just to change micro- to nano-sim from Singtel. >.<
i1magic
Anyone here have Bluetooth pairing issues with their RN3 ?
I have a RN3 Pro on Global rom 7.3.7.0(LHOMIDD), which just won't detect & pair with my Samsung LeveL headset.
The same headset works with my old S4 9506.
It pairs okay with my S4 for file transfer though.
Something wrong with it's Bluetooth audio profile or I am just unlucky enough to have a non-compatible headset?
Do you have another brand's BT devices that you can try with? Or those cheap BT earpiece that you bought online?
My RMN3 is on 7.3.6.0 and no problem with BT connection for the cheap BT earpiece that I have.
kelvinti
Yeah!
3 more days for the next MIUI8 beta update...
Hopefully they fixed those reported bugs from the current beta...
No way back to MIUI7 now..
Oinkize
Yeah!
Cannot wait for the next update. Tomorrow we should be able to see the change log...
kelvinti
Will the new update require to reformat the phone again?
Nope!
It will be an OTA update once you are on MIUI8 Global Beta 6.7.5 all the way until official Global Stable MIUI8 in August 16th! :s22::) Nothing will be wiped out! :)
Amazing isn't it? :s22:
All should up their ass to MIUI8 asap !:s13:
kelvinti
New firmware 7.5.3.0 is out.
:eek: Now still got new firmware...Good for MIUI7 based users. :)
>> Sniffer Dogs! Mobilization has been activated now! :s13:
I'm sticking to MIUI8 Beta. It has been good..
DigDub
7.5 is update from 7.3? how come skip.7.4? 4 unlucky number?
i1magic
Too much to take?
Better don't complain! Kekeke.
The more frequent the merrier bah! :)
My Mi TV 2 55" is using beta firmware liao, think my phone might as well also use beta firmware. LOL!
How to update to MIUI8? Will it wipe all the data?
kelvinti
Wah! Mi TV also go beta firmware one ahh! Xiomi can do,really! :s13:
To update to MIUI8 Beta. 2 methods:
1. Fastboot ROM method will wipe out everything!
2. Recovery ROM method will wipe out everything except the folders and files that you have copied and created to the internal drive earlier.
