Xiaomi Redmi Note 3
halocast
Does anyone have any recommendation for stylus to use for taking notes and writing on the RMN3? I bought adonit jot dash but it doesn't work well with this phone. Or RMN3 just not suitable for writing?
imo if u looking for writing.. the best bet would be the samsung note 7.
:D
DigDub
tested this.. apparently its the way slient mode is enabled.
when silent mode is on.. the ring and media vol is both muted.
which results in the bell. the ring is also becomes not highlighted.
otherwise .. if only ring volume is muted.. no bell appears. the ring is highlighted still.
not sure if its intended to be this way.
alarms still work even if silent is enabled.
hmmm... I remember in miui 7, lowering the volume all the way will also have the an icon. maybe next update should bring it back in case users dunno they have silenced the ringing volume.
PC-User
Noticed that the volume scale has changed from 7 to 15. For example the previous volume setting of 5/7 now has become 5/15. Missed one phone call just now then noticed.
i1magic
Does any of you experienced high battery drain on your Redmi Note 3 Gallery app?
Sync is disabled. But dunno why such high drain.
I took the micro SD card out, copy all the files out and then reformat the micro SD card. Then copy all the files back.
Still the same. Si bei sian. Think need to do a reset liao.
batniss
how to off the orange thingy with MIUI8?
Previously i just need to enable/disable swipe lock i get the pocket option to be disable then re-on the slide thing.
Now the moment i enable swipe, it goes back to enable pocket option.
skrw105
How to turn off the promoted app icons advertisement?
Originally Posted by JuXn5566:
Any form of ads in MIUI can be turn off. The only notification ads I saw on global rom is from MIUI browser app, which can uninstall without rooting. Basically just use chrome.
The promoted apps can turn off by clicking on the folder name and turn off the switch.
credit to juxn5566
otacon
credit to juxn5566
Actually where can I find the folders?
Sent from Xiaomi REDMI NOTE 3 using GAGT
lexmarq
Hi, anyone on MIUI 8 managed to find the option to turn off screen wake for incoming notification?
FinalTidus
Hey guys...
Just saw the miui 8 update which needs 1.3GB of data...
Still on 7.3.2.0..
Any improvements in battery life and performance?
