Xiaomi Redmi Note 3
Hyperephania
6.9.15 is the Beta/Developer rom.
8.0.1.0 is the official rom. Xiaomi calls it Stable rom.
6.9.15 has more features that are not found on 8.0.1.0. :)
Will the features in the developer rom be avail in the stable rom in time to come?
Basically the developer rom is better?
kelvinti
It will, eventually!
Basically, if you like to experience or try new features faster than anyone else who are using the officially published rom, Developer rom is the ultimate choice. :)
So far, the Developer rom is better. :)
Hyperephania
By changing from stable to developer, will i lose my data?
otacon
So which method recommended to flash global beta? Can guide me to flash my rom?
I have done flashing rom for my S2, S3 and S4 before
kelvinti
Follow this guide.
You shall start the reading from the "For Normal Flashing:"
http://en.miui.com/thread-235865-1-1.html
kelvinti
Is our bootloader locked? Does it matter if is local or export set?
Be it local or export set and be it the bootloader is locked or unlocked. It doesn't matter at all for Redmi Note 3. :)
Just leave it locked and perform the flashing. :)
Hyperephania
It depends on your Apps.
Some Apps are working in Stable rom but not in Developer rom.
I have no statistic on that.
However it is pretty rare! :
Apps aside?
Would the developer rom screw up some **** one day then have to switch to stable? :s13:
kelvinti
Apps aside?
Apps aside. Go for developer rom.
Developer rom will not screwed one as it is produced by the official Xiaomi developers team. Not by other 3rd party teams. :)
kelvinti
Ah alright. Will it take very long to flash the rom?
The actual flashing process takes less than 5 minutes from start to end.
For a first timer, reading and understanding the guide as well as preparing / downloading all the required tools/apps for the flashing will probably take more than 30 minutes depending on the level of technical understanding or knowledge of an individual.
kelvinti
Will flashing to another rom change my phone device ID?
Nope! Nothing will be changed as far the device is concerned. Nothing to worry about that at all.
Warranty will not be void as well if you have a local set as the developer rom is produced by the official Xiaomi team. :)
