Xiaomi Redmi Note 3
skrw105
From what I can see, no leh. I tried to find the option to disable "Proximity sensor" but cannot find leh.
setting ->about phone ->Kernel version -> Tapping it many times -> will lead to Q/C Test -> there taking up 13th -Proximity Sensor.
test by covering top part of phone=0, uncover=5.
kelvinti
Hmmm...
Same same to my other KNN Note 5 SP. Same problem as yours for calls.
I also couldn't see any "blockage" of sensor holes from my sp.
However, the moment I removed the SP. The call sensor is working right away.
For my case, the poorly designed sp was to blame. :(
A.r.S.e.N.i.C
Anyone experiencing high battery drain from Google play services? Left my phone overnight and Google play services kept my phone awake and dropped from 90% to 60%
hzseesee
I still have yet to receive OTA update notification for MIUI 8. My RN3 set is from M1. Currently still MIUI 7.5.3.0 stable version. Updater keep saying no new update available. Any expert here can enlighten Me? Thanks.
Sent from Xiaomi REDMI NOTE 3 using GAGT
flame2000
Tats weird. The moment i setup my Wifi n connected to it, I goto updater n it prompted me to update to MiUI8,
My set also from M1.
Computeron
Donno... I what is making my phone awake all the time
flame2000
Hi, does it make sense to wait for RMN4 or just grab the RMN3 now?
RMN4 is Mediatek CPU. And it was announced recently that Xiaomi won't make one with SnapDragon CPU. Maybe later they might release a SD RMN4? No one knows. Just grab the SD RMN3 now. :D
iamnagel
Note3 is good enough.
Note4 SD version is just a rumour at the moment. Unless u can wait ... Choice is yours
If u wanna wait for note 4, wait for the snapdragon version and stay away from the mtk version.
Sent from Pikachu using GAGT
Thanks for your advice. I ordered one through lazada with code lelong10. Total $199.00. Shopback credit another $3.40
Impressed with how cheap a smartphone can be these days
Sent from LGE LG-H815 using GAGT
dyland
scientific calculator MIUI 8
Any tried using the scientific calculator ?
For some strange reason if I want to find sine(30) I get the wrong answer and also negative value too.
Is this a software problem? or it needs to be reset altogether before it can function properly.
