Xiaomi Redmi Note 3
blade39
Correcf bah!
The latest miui (not sure it is a Stable or Beta rom) supports 4G-3G already.
Previously, it was just 4G-2G....
According to the screen shot by Norman Chan below, he is on global rom version 8.0.1.0 which i am also currently on.
But i cant seem to find any 3G network for my Sim 2 which I choose Dial as the default setting for it.
My Internet is chosen as Sim 1.
If i choose Sim 1 to be dial and Sim 2 to be internet, my sim 2 will be able to find 3G or 4G network.
James961
You guys with smartcell sets also got a box with chinese characters? Just got mine, first look thought its china set sia :s22:
Sent from Sony D6503 using GAGT
Oinkize
Can you pull down your notification and see?
treeskull
Doze on the go kym?
Sent from 你是我的小啊小苹果儿怎么爱你都不嫌多红红的小脸儿温暖我的心窝点亮我身命的火火火火火火 using GAGT
treeskull
bitwise
Quick question: while using an app and you pressed the button to show all apps, then swiped up all the apps, why is the current app still open? Cannot close it like that unless in the homepage. Is that by design or a bug?
I am using MIUI8 and expected operation is it will close everything and default to home screen.
DigDub
updated to 8.0.2.0 global stable. not sure if placebo effect, feels faster. everything else seems the same.
flame2000
I updated to 8.0.2.0 global stable yesterday. Dun feel any diff too. Battery life no change. But some mentioned VOLTE is enabled in miForum. Where to check the VOLTE setting?
