Xiaomi Redmi Note 3
shadow84
flame2000
Managed to do it although it was confusing at start. Sad its still in lollipop instead of marshmellow.
I hope Xiaomi release marshmellow soon. I want the doze function. Read that it can extends battery life by almost 30~40%.
Hongyan
Hi.
I bought my Redmi Note 3 from "Redbean" in Sim Lim square a week ago, any idea if this is an authorized seller of Xiaomi?
I noticed that the SIM tray can put in 2 SIM only, but not "hybrid" one that can put in microSD card, and the seller told me they sell all Redmi Note 3 in that dual SIM card tray, not hybrid one. Can I ask for a change in Xiaomi service centre?
Thanks folks.
DigDub
xiaomi marshmallow no doze. they implement their own battery saver.
flame2000
I currently using Xiaomi batt saver function. Set to auto turn on at midnight n off at 7am. So far batt life is really good for this phone.
Hongyan
new to Xiaomi. Redmi Note is my first xiaomi.
a simple question, does MIUI updates automatically or we have to update manually ? seems a lot of discussions on MIUI updates here...
thanks.
amazingone
Hi.
Thanks folks.
No, the Redbean is not an authorized seller by Mi Singapore. It's likely a parallel exporter.
You likely got the older Redmi Note 3 that comes with the MTK Helio X10 SoC, and nope, you can't get it change from Xiaomi local service centre.
Sent from Sumire using GAGT
porky_88
just got a used mint local unit. power on... and updated to developer's rom...
phone feels speedy.... but miui 8 not my cup of tea.
any recommended aosp based rom or cm based rom that preserves all the functionality including volte and dual sim?
porky_88
if dual sim slot.. and no sdcard... 99% you brought the MTK version.... thought it EOL when the snapdragon version was released??!!
porky_88
Can I check redmi note 3 snapdragon confirm cannot 4g+3g even if updating to latest global developer ROM?
just updated to developer rom moments ago.... it is on 4g/3g now, umts on sim1 and lte on sim2... will test and play around with it a bit more
Oinkize
coz there is no such menu option? at least none that i can find
There are no settings for doze in any marshmallow phones.
I read up abit and doze will only kick in after certain conditions are met.
tanchoo1
Hi.
Thanks folks.
I hate to tell you this but it sounds like you "anyhow buy" without doing the proper research first.
Redbean is definitely NOT an authorized reseller; you definitely got an export set with no local warranty.
How much did you pay for it and for what model?
You almost certainly got the version with the MTK chipset. This version does not have Global ROM, so you are stuck with China ROM.
You should be getting the Redmi Note 3 "Pro" version which has the superior SnapDragon 650 chipset. Everyone should be buying this as it is faster and the SAME PRICE as the MTK chipset.
I thought we already learned from the Jover Chew incident in SLS...
Your best approach now is to try to go back and get a refund or exchange it for the "Pro" version.
By the way, for export sets, specifically the "Pro" 3GB RAM / 32GB ROM model, you should not be paying more than about $218 for it. That's the price in Lazada without any discounts, and it comes with FREE delivery. If you paid more than $220 for your phone, you got conned big time.
Buying it today (Friday) will knock 10% off the price using DBS / POSB credit cards and the appropriate discount code which can be found on the Lazada website.
tanchoo1
Unscrupulous parallel importers just trying to get rid of dead stock and inferior models... no one buys the MTK version.
Unless they got Jover Chewed.
