Xiaomi Redmi Note 3
juuzbe
see if u value support and warranty? unfortunately their warranty not global.. if it was.. it would be good man.
its only this that's makes the difference.. maybe global rom if u nitpick haha :o
Warranty i don't expect much for not so expensive phone. My child's Redmi 2 got in locally, i think one SIM slot abit sort sort, also lazy to go service center to repair. hehehe.. Note 2 advantage is their OS already suits googleplay app. Easier to play around with.
On the other hand Note 3 currently only china OS right? What attracts me in Note 3 is their 3Gb Ram and 32Gb storage that probably works faster.
Had used Redmi phones, unroot one, even with their 16Gb storage, usually with lots of whatsapp or media chats, will tend to make the phone hang hang.
Seifer28
Anyone who bought their redmi note 3 from New Star Electronics on Lazada feels anything funny abt their phone?
1) mine cannot OTA update to 7.0.19.0
2) mine has a very funny serial number (under about device --> status)
jedi5diah
screenshot
Seifer28
screenshot
jedi5diah
as long as imei matches the box, i don't see a prob.
either manual flash (i reco dev rom) or reset and update (reinstall play store)
Seifer28
yeah
everything seems legit.... except for this serial number + i cannot OTA (stuck at 7.0.11.0)
halocast
currently is china miui rom.
haha i think no need to answer.. in yr heart already answer liao..from this reply..... just hoot only. :s13:
cscs3
Yes. Note 3 not yet has global rom.
yonglimm
how come the serial number so funny?
1st, it is sealed when u received it?
2nd, does this serial no tally with the one on the box?
if ur answer is no to 1 and 2, then kongsi fatt choy to u ...u got urself a shanzhai redmi note 3.... :s22:
yonglimm
New star electronics....hmmm...there is also a shop in SLS with dat name but dunno whether issit the same company, ..... use to know some of the ppl there.....if it is the same company, then all i can say to you is :
GOOD LUCK BRO!
:o
Seifer28
does this serial no tally with the one in the box? If not, then kongsi to u ...u got urself a shanzhai redmi note 3.... :s22:
The IMEI tally with the box
everything is working well.... even the fingerprint sensor....
Ran antutu benchmark score also correct....
So i really don't know whats with the serial number.....
yonglimm
aiya, if everything is working well, then donch worry so much and juz enjoy the phone lah.... :s12:
