Xiaomi Redmi Note 3
porky_88
by right... if every vendor follows agreed standard.. then a device will draw only the appropriate current
by left... anything goes. that's why it is best to have a usb charge monitoring device. then u will know how the actual voltage and current drawn...
if everyone follow standards.. there won't be chargers/devices exploding/catching fire. we live in very exciting times!
sggirlsareflatchested
No worries. The phone will be smart enough to take in maximum safety voltage to charge.
alright thanks for your reply!
batniss
Strange, did anyone experienced the same issue that after MIUI Upgrade, you are unable to change password (i.e when you tried to reset your fingerprint that page) due to incorrect password?
My password is definitely correct though but it keeps saying invalid.
Edited: xM reduced it to 4 digits instead of the numbers of digits of your choice. Weird.
ZrE0_Cha0s
guys just checking if SG model can have 4G+3G sim?
i mean like is there any issues where the 4G and 2G / 3G and 2G something like thtat?
hotstuff4u
High Honorary Member
My xiaomi the push button kinda not responsive...
It is not that terribly bad...
I have warranty with xiaomi cos I buy from m1...
Wonder if it is hardware issue ....
Anyway I enabled volume button to unlock n widgit a lock icon on my screen le :(
Use for three mths since September 11th :(
Oinkize
Hear say local set got marshmallow already. Then supports 4g + 3g.
happyko
Was hoping to get another Note 3 pro. Too bad this 12.12 there is no attractive pricing like the previous $188.
clay9477
Come. I got lobang. http://www.lazada.sg/xiaomi-redmi-note3-pro-332gb-gold-export32gb-9223453.html
Use OR16FINAL12 bring price down to 176. If voucher cannot use already use CitiBank card bring down by 10%. Also cheaper than $188.
BusteR
make sure is not the special edition (kate)
this variant many upgrade stock / flash rom problems. No case n extact fit sp due to 2mm longer 152mm.
buy only if you think you will upgrade only once every few months.
Yes, from Swooop. Don't care for colour as long as it's 32GB. Hopefully this comes with Global ROM :)
clay9477
Just received. Is Kate version. Sigh had hoped it was Kenzo. But nvm lucky the tpu casing fit still and screen protector maybe a bit weird, top and bottom will have minor gap but can still use the Kenzo one.
clay9477
Kenzo and Kate updates are now on par. Both on stable mm update already.
