Xiaomi Redmi Note 3
PholkLorr
One thing i really hate about MIUI is the ram management. The worst ram management ive ever used in my whole life. Feels more like a 1GB RAM phone, and im using the 3gb SD version.
Even after tweaking and supposedly disabling all the ram optimizations, the device insists on killing apps up down left right center. Playing pokemon Go, go to desktop to use my bus app, go back to pokemon, have to restart and vice versa. That's just one example.
Another bad one is when youre FBing or surfing a browser and u go out and open another app then go back to FB/Browser, it have to reload it, which means whichever position/page your browser/FB was at, it is gone and starts right from the top, wasting alot of time and also probably waste your internet data since u're as good as reloading a new page.
ktyandkyc
that's where i thot CM will be useful
BusteR
MIUI 8 to bring along split-screen multitasking feature
PholkLorr
i dont really care about split screen, i just want my apps to not get killed the moment i press Home. Was never a problem when i had my LG G4 with 3gb of ram too
BusteR
"In case you don't already know, the functionality allows users to accomplish two tasks at once by opening two apps side by side (in parallel)."
http://www.gsmarena.com/marshmallow_update_starts_hitting_tmobile_galaxy_note_4-news-19062.php
i'm new to miui - perhaps above "accomplish two tasks at once" might be the missing feature we all needed.
BusteR
Ya i also thought of going CM route but then it doesnt support POkemon unless i do that magisk xposed thing. too much of a hassle
i also tempted to go CM but i read volte and fingerprint *might* not be working. also read my kate varients have different fingerprint hardware hence might not work out of the box after flashing...
will try miui for 1 month - if really very jialet, will jump to Resurrection Remix or pure CM.
ktyandkyc
hope to get my phone tonight. Does anyone know if its easy to change the internal battery of the redmi note 3?
clay9477
Not hard, go Youtube watch the tear down videos. Only problem is battery will last for 2 years after-which you probably buy new phone already. :s13:
ktyandkyc
I seriously hope so... my iphone 5s' battery became sot exactly after 1-year apple-care became obselete and have (painfully) tried to replace batteries from qoo10 & aliexpress. Still living with very very poor battery life now
ktyandkyc
Has anyone managed to flash CM roms onto kate version? Or has anyone able to successfully unlock the bootloader?
skrw105
ota for global developer rom.
ceestudent
Just update to 8.1.1. stable ROM from OTA update.
Notice that It can detect 3G+3G with my singtel prepaid (finally..). No 4G at my place now.
Anybody can concur on the above finding?
clay9477
This feature has been there since mm was available on developer rom. It's just stable rom is last to the party.
Also some users have mentioned option to choose LTE disappeared. Just bug but will have to wait for it to be iron out.
PC-User
8.1.1.0 update: don't feel any obvious difference/improvement but 2 annoyances. 1) Every reboot will have to key in password 2 times! First before 'starting Android' then upon entering home screen. 2) Every reboot will remind about the SD card.
Also the reboot is taking much longer and initially the keyboard will flash and freeze for a while before password can be entered.
A.r.S.e.N.i.C
Are y'all able to change whatsapp notification sound to custom sound? Tried changing it but it keeps going back to the default message sound
JuXn5566
Recommend you to make local backup on sd card, factory reset then restore from your backup.
