Xiaomi Redmi Note 3
halocast
anyone running on the marshmellow?
how's it like? battery life and perf?
clay9477
what is stable mm update? **** man i bought my screenprotector & casing alrdy, not sure if it would be kenzo or kate..
Screen protector confirm no issue one. Most sellers is sell Kenzo one.
Just that top and bottom got 0.1mm gap only haha.
If you buy hard casing then got problem. If TPU material can just squeeze a bit as after all only 0.2mm diff.
clay9477
Android Marshmallow! Originally on developer rom only but recently stable rom has been slowly pushed out. Currently in beta testing but before Jan can push out to all.
clay9477
Stable Marshmallow for Kenzo got a few problems at the moment, particularly battery drain and a bit minor stuff here and there. With future updates will get better.
clay9477
Anyway Bros, those looking for Redmi Note 3 Pro 32GB as new sets, SG like no more stock liao. Really is scarce to find one now for export sets! Haha not from Mi Store.
eviler
On 8.1.1.0 and no issue so far. No app hanging, no random crashes, batt life better than 8.0.6.0, lasts up to 1.5 days on light usage.
clay9477
Bro the lazada offer $199 worth to get bo can upgrade to Marshmellow :D
Yes if buying the one I recommended the 3GB/32GB export version. But take note is Kate version so by default, miui 7 is marshmallow based already. Latest miui 8 also marshmallow. So when flashing choose special edition rom. Additional antenna means the phone is 0.2mm longer.
So casing need to buy from aliexpress as taobao don't sell. Use keyword, Redmi Note 3 Pro special edition or Redmi Note 3 Pro International 152mm. Find the case you like and use ezbuy to buy. Try find sellers from Guangzhou and Shanghai. That is if you want fast, else purchase from aliexpress yourself eta is from 2 weeks to a month.
Screen protector wise can still buy from normal shops, 0.1mm don't cover top and bottom no big deal as the main thing is to cover the entire screen can already.
Don't kan cheong, use OR16FINAL12 code. If try now cannot wait until 12am later as tmrw is last day for the promo code. Savings of $23 okay. Don't play play.
BusteR
Special Edition - Kate (BL unlocked officially)
TWRP + SuperSU + 6.12.8 EU ROM
:s13::s13:
Oinkize
Remember to use with shopback...
clay9477
sigh,i shouldn't have paid for $3 delivery fee to lazada :s13: I would like to flash to CM rom but couldnt do anything until the unlocking is approved.
Haha my first time I also pay $3, subsequently realised economy also equally fast like no diff.
BusteR
hold CM 1st. try miui 1st
i researched alot CM vs MIUI camp is 50% 50%
got 1 guy said redmi phone is meant for MIUI and if he buy any other phone - he will have flash CM right away.
anyway CM like not polished yet. missing volte and fingerprint etc.
of course can flash this flash that to fix.. but only if you siao on.
i'm past the xda siao on every few days flash flash stage ;)
hotstuff4u
High Honorary Member
How come these two days my handphone very warm. Usually not like this...
39 degrees is ok or not
ktyandkyc
Thank you for ur info. My bro using cm for note 2 and highly recommend that due to battery life. The stock rom that comes with the export set can be just used straight away?
