Xiaomi Redmi Note 3
dolphinv
Yes. Excellent upgrade and very snappier . Never notice any battery drain. Seems like memory mgt improve alot over all. 8 always out out memory
Sent from null using GAGT
Haha noticed now they dont show the ram usage anymore though. Yeah so far no random battery drain.
But GPS still doesn't work at all. Anybody else have this issue? Cant get a lockon
batniss
Bo. Mine lock perfectly.
Extremely snappy now
noobie9999
for ram usage display, you can enable it manually.
when you arrange your icons, you see "wallpaper“, “widgets”, “settings” on bottom. you can click settings-> more -> show memory status.
molecule
Think your GPS chip is fried. Had similar prob with a previous fone, tot was software but despite updates GPS still could not lockon.
kopi22
Funny... Updated the phone but unable to use the split screen mode. I don't see the split screen option over at the app switcher. Anyone having the same problem??
clay9477
Redmi Note 3 no split screen mode for MIUI as still Marshmallow version. Split screen only available on Nougat MIUI.
If you want split screen can download other custom Rom like Lineage OS.
kopi22
Oic. Thanks
Sent from Xiaomi MI A1 Running Oreo 8.0 (January Patch) using GAGT
molecule
After one week on the new firmware, two thumbs up. Feels like a flagship phone :). Too bad this is not my main phone due to camera.
Now wondering if any upgrade to camera sw and quality.
PC-User
I agree this is by far the best firmware upgrade in terms of performance improvement.
Hailgod
you can try nitrogen os + gcam.
Sent from Xiaomi REDMI NOTE 4 using GAGT
carboy00
Friends with redmi note 3 SD 650, will you upgrade to redmi note 5 pro or redmi 5 for 18:9 display?
Definitely Redmi Note 5 Pro for the overall bump in specs compared to Redmi Note 3. From initial reviews I have seen, the camera on the Note 5 Pro is quite an improvement from past Redmi Notes too.
Sent from Xiaomi MI 5 using GAGT
PC-User
I think he meant would we forgo SD650 for the trendier 18:9 look but a downgrade to SD625.
grapewall
Qoo10 selling brand new export set at 170.
Use cart coupon save another $5.Free delivery.
I bought one set due to my old set 3.5 socket faulty - always showed headphone connected.
I got the same problem. How did you resolve the problem?
grapewall
I'm still using xiao mi 2, bought in 2012. Yes, still got software updates, although may not be for long since the hardware cant support any further and not many users already.
dolphinv
For me exact same problem just happened about a week ago.
Software solution: Use the app soundabout download from playstore. It allows you to choose where to output the media to, i.e speakers or headphone jack.
Hardware solution: change headphone jack. I still waiting for replacement part to arrive from taobao, but from online guide need solder sia so quite difficult.....
But upon further inspection the problem is cause a metallic part inside the headphone jack chip off (broke) that's why it always detect as headphones plugged in
grapewall
You got buy extra? Can i buy 1 from you?
dolphinv
yea i bought 1 + 1. 1 ezbuy prepare shipment since before cny. the other one havent even dispatch to ezbuy warehouse. I use sea shipment. Will update you after i try on my phone bah. (can pm u the link if u want but dont really need sell haha only 1.70 without singapore shipping) might take 1 month. lol (all the delay)
but use the software fix first. i also using
