Xiaomi Redmi Note 4G
Bieffe
I've just gotten my Redmi Note 4G, and having 2 issues:
When I connect to PC, it only shows me the MI folder, but not the internal
storage folder :( I have been trying to check about drivers and all but still can't detect it on my pc (running Win 7)
However, when I use FTP connection, I get access to it.
I want to do this, because I want to transfer my WhatsApp backup folder from my Mi3 to new Redmi Note.
Despite using ftp connection (as I can't access it via usb), I am unable to transfer the backup file in. I created a new folder on my new phone, and tried to transfer just the backup file in, also can't. Its not allowed.
Anybody knows why, or how I can get around this? :(
Would love my whatsapp chats back (not just the groups)
I think got to do with the permission of the folders. I suggest you copy another of the backup. So both internal and external also have the same file.
then u try bluetooth the file over to the other phone. Still cannot save the backup in the sd card then plug the sd into the new phone and then copy from there?
Evielicious
That seemed to have worked!!! Strange.. :( So disturbed by this.. i didnt have problems with Mi3... sigh. should i be regretting.. I noticed that on Note4G the images are less crisp..
Going to try and start WhatsApp now, hopefully it uses the backup and picks up the individual msg threads :)
**Edited:
IT WORKS!! THANK U SO MUCH BIEFFE!!! *HUG*
haha08
Does anyone have the problem of not bring able to switch to the front camera?
Bieffe
**Edited:
if you are a lady pls come hug me.
The mi3 sure sharper. As ur new phone has lower resolution.
haha08
Nope super sharp and no problem.
Thanks..brought my phone down to check and got it repaired in 2 hrs..
good service..they have ready parts for replacement.. did not expect them to get it fixed within the same day.
gotta say well done to xiaomi!
Hope they keep up the gd service and value!
GreenArrow2002
I've rooted and installed PhilipZ recovery. Possible to get back to the original Mi recovery as I've problem using PhilipZ to install a new rom. Flashing stopped a few seconds after starting.
blurrz
Does anyone knows how to check wat apps suck my data plan? Since changing to this phone my data uses up a lot and very fast. Prior to this been using iPhone 4 and Samsung note No such problem.
Bieffe
Ya hope they keep it up. Is with these ppl that phone price will go down.
But once their business become good and get more market share it will most likely end up like the rest of the big boys.
caterham7
Pull down window shade to see notifications. Just above the word "notifications" is your data usage, e.g. "Today: 35MB"
Click on the number to go into Data Usage
Click on Stats to view usage of data by app
blurrz
Thanks... I checked... nothing sucks up my data at all... I only used say 100MB for today... clicked this month only 1GB...
Seems not very accurate?
Epee
Quick question for fellow RedMi Note users -
When I plugged in my Audio Technica ATH-M50 or the ATH-ESW9, sometimes the phone will think it's a headset (as opposed to just a normal headphone) from the icon on the status bar. And then Google Now will be invoked randomly or there will be random clicks registered by the phone from the phantom buttons.
This does not happen when I plug in my ATH-CKS77 (an in-ear). Any idea? I'd prefer to listen to the ATH-ESW9 instead but the constant switching to headset mode is killing the experience.
caterham7
new discovery, for me at least
paiseh if this was mentioned previously
the wifi at my room/office is quite weak, as it's located far from the router
suddenly remembered about reverse tethering, so did some googling
xiaomi has a app that you can install to enable this
小米助手
install on your pc, then connect phone via usb
there will be an additional toggle appearing in notifications panel
"use computer's internet connection"
Mr. Bushido
Hi all, I just got my Redmi Note 4G to tide me over until I get my hands on the Xiaomi Note Pro :s13:
Anyway, I notice it's running MIUI V5, not V6. Anyway for me to update it to V6, because I don't really like the skeumorphic design of MIUI V5, prefer flat design of V6.
mingfreakrsx
You can try updating to Note 4G's MIUI 6 Developer ROM but it doesn't comes with Google Play Services pre-installed so you have to separately install it.
Sent from my Mi phone using GAGT
Bieffe
Sounds like too much of a hassle. I think I'll just wait for the official update to be pushed to my Note 4G. Thanks anyway!
True don't wanna mess up the phone.
how u ppl backup....as other phone have their defacto app and PC software like iTunes or KIES to do it.
caterham7
KHIMIBH22.0 stable version appeared when i checked phone update
phone offered option to backup before update; backup in progress...
Mr. Bushido
Is the screen protected by Gorilla glass? Safe to use without screen protector? I currently have a matte one on mine, but I am very tempted to remove it, cos with a matte screen protector, the image on screen is less clear
