Xiaomi Redmi Note 4X
peejay05
anyone can help shed some light on this.
so far, i've read that only the note 4A only allows 2G on the 2nd SIM, and that the note 4 and 4X allows 3G on the 2nd SIM card. I was about to place and order on (http://www.lazada.sg/xiaomi-redmi-n....campaign-267.0.0.O67iHg&ff=1&sc=IQsB&boost=2), when I saw that q&a below quote:
"I understand your concern and would like to inform you that in Redmi Note 4, when two SIM cards are used simultaneously, the primary SIM can support 4G calls and data while the secondary SIM can support 2G calls only. Therefore, you will not be able to use dual sim as telco has terminated the 2G line. However, in some of our Xiaomi devices there is an update which will be rolling out and you will be able to use the 4G network in first sim slot and 3G network in second sim slot after the update."
Anyone knows if the update is already out? thanks in advance.
wackykid
i only know that redmi 4A only allows 2G on 2nd SIM... there is NO note 4A... only note 4 or note 4X....'
this thread is not for redmi 4A...
regards,
wacky
peejay05
regards,
wacky
Thanks for your speedy reply. Perhaps I wasn't clear, but the phone I was intending to buy is the note 4 or 4x bcos I need the 2nd Sim to work. The link is for note 4, see quote below also. Hence, I was perplexed bcos I thought the Redmi 4a is the only one that supports 2g 2nd Sim.
wackykid
edit:
if u see the response again it says:
Hi Buyer,
Thank you for writing us.
I understand your concern and would like to inform you that in Redmi Note 4, when two SIM cards are used simultaneously, the primary SIM can support 4G calls and data while the secondary SIM can support 2G calls only. Therefore, you will not be able to use dual sim as telco has terminated the 2G line. However, in some of our Xiaomi devices there is an update which will be rolling out and you will be able to use the 4G network in first sim slot and 3G network in second sim slot after the update. The devices which will be supporting the 4G/3G network are as follows:
• Redmi Note 3
• Redmi Note 4
• Mi 5
• Mi Max
Delivery will take estimated 3-4 working days.
Thanks
means that note 4 supports 4G/3G... probably some template answer from whoever that posted that... :s22::
regards,
wacky
peejay05
edit:
regards,
wacky
Yes I've read that and because the grammar is "update will be rolling out" and not had been rolled out, thus my question was if anyone knew that the update has been made available. I've messaged the seller (official Xiaomi) and not gotten any replies so just trying my luck here.
limjialok
Hi, is $50 worth it To buy the 4gb/64gb verison? I am considerinf betweem 3gb/32gb At $250 or 4gb/64gb at $300
YCT_49
I am quite shock to see that 1 seller in Qoo10 is selling Xiaomi Redmi Note 4X 32/3 GB around S$60 only which is a quarter of the market price! Anyone know whether it is underground clones and not original?
TheOne
Wasted my money on a tempered glass screen protector on Qoo10, only to realise the curved edges make it impossible to apply one properly, unless you don't mind all-round air bubbles. Where can I find a proper one?
resurrexia
Can someone please advise, whether I should just buy Note 4X or wait for OnePlus5? My old jailbroken iPhone screen shattered so need to replace soon.
I plan on using LineageOS and Kali Linux Nethunter on my phone. Root access and xposed is very important to me. Will also be playing some games (Crusader Quest, and some other JP games).
I like the pricing of Note 4X, but not sure if suitable for me. Help?
Audiology93
Note 4x might not be the best for gaming due to the 625 inside. It is very power efficient hence can't be compared to flagship grade phone like the OnePlus 5. You should be able to get better firmware support on the OnePlus 5. But that being said, it might take another month or 2 before you can get ur hands on the OnePlus 5. If you can wait for 1-2 months, I suggest u wait for the OnePlus 5. If urgent, get the Note 4x 1st to tide u around, sell it once u manage to get the OnePlus 5.
Sent from Samsung SM-G950F using GAGT
resurrexia
Hmm ok. Sounds reasonable. I think I will get Note 4X to tide by first. Do you recommend 3+32 or 4+64? Not sure which one is better as I heard MTK is worse than SD chip.
ipevery
Challenger with local warranty at redmi list price. if u can't wait.
not sure if they carry 4/64 though. 3/32 definitely available.
Oh... Then in terms of specs is 4X 3+32 better or local 4 4+64 better?
Btw, can recommend physical shop to buy from? Don't really want to wait for shipping.
Audiology93
If you don't care much about local warranty, you can get it from iSky Trading from their shopee or Qoo10 store. I just collected my Redmi Note 4x from them just now and the service was great and I updated it to the latest firmware on the spot. If you care about warranty then get the Redmi Note 4 625 from MI Store in Suntec or LAZADA for local warranty.
PS I'm not affiliated to them in any way.
Sent from Xiaomi REDMI NOTE 4 using GAGT
wackykid
