Xiaomi Redmi Note 4X
ZrE0_Cha0s
is this phone the latest xiaomi one in Singapore?
or should i get Mi Max?
my redmi note 2 screen cracked, or should I replace the screen instead?
1. in terms of export set yes latest xiaomi redmi phone
2. up to u as we have no idea whats your usage beside replacing your old phone
3. depends on u thinking if u still want to use your old phone or not. as screen replacement might not be cheap, next your phone is no longer in productions so u might be charge at a higher price or u cant replace it due to stock availability.
s-ghost
High Honorary Member
if I want a set with local warranty from official xiaomi store, what's the latest model?
yeah the replacement might not be worth, unless I know how to change myself
wackykid
Hi,
For the local RN4 3GB/32GB set, does it come in black colour? I only saw gold & grey.
Where can I get it cheapest?
Saw Lazada @ $259 & Hachi.tech @ $259 + 2% rebate.
Any Lazada CC promos?
i recently bought redmi note 4 from qoo10 for my mum... it's listed at $270 but with $30 cart coupon + 3% from $200 worth of gift vouchers... it's down to $234... :)
regards,
wacky
ZrE0_Cha0s
regards,
wacky
got mi store in qoo10 ???
wackykid
ZrE0_Cha0s
guyferic
cscs3
wackykid
Qoo10 is no more a good place for internet shopping anymore.
qoo10 used to be better than now... but now still good with new coupons every now and then...
u got better alternatives mah...?? :s11::s11:
regards,
wacky
wackykid
Can find the casing for SD625 version at KSL?
i bought the casing on shopee (utilizing DBS $7 discount)... the one i got can be used for both versions....
qoo10 i also got see alot casing....
regards,
wacky
delfina
regards,
wacky
I see shopee seems to have free shipping but qoo10 shipping need $4
Deathzz
Is there really a perfect fit screen protector for this? Just bought 1 from new star and the free temper glass doesn't match fully. Guess it is due to the curve edges
OmegaSupreme
Yap tats y i nvr opt for the screen protector,tat time i bought the phone the screen protector cost 3 or 4 dollars not free,the casing oso not match,suppose for note 4 not note 4x and cost 3 dollars too.
For whole piece tempered glass there isnt any perfect one. Maybe u wanna try this type:
https://detail.tmall.com/item.htm?spm=a220m.1000858.1000725.21.TSvSRn&id=548645509429&skuId=3330904165133&user_id=366671354&cat_id=2&is_b=1&rn=f94ff3f1bbf514f528261238a59389e9
revhappy
Hello guys I have a question.
On the Xiaomi download page for original ROM for redmi note 4x, there are 2 versions for the China ROM one for 3gb and another for 4gb. But there is only 1 global version. So if I buy an export set can I install the global version on the export set? I want to be sure I won't brick the phone
Sent from Xiaomi REDMI NOTE 2 using GAGT
