Xiaomi Redmi Note 4X
amazingone
revhappy
Don't install the 4GB RAM one, install the 3GB RAM one.
Sent from an Xperia using GAGT
Thanks the phone came already installed with the global ROM.
I made this post in the thread for 3G+4G phones. But I will repeat it here as this is more focused for note 4x
"I noticed, even though this phone is note 4x, it's global ROM version number is same for both note 4 and note 4x on the xiaomi website. This phone also came with global ROM version 8.1.15.0.MCFMIDI.
Also in the about phone section the device name has Redmi Note 4. It doesn't have x in it.
So I believe Redmi Note 4 and 4X SD625 are identical devices.Only difference is 4X means China ROM, 4 means global ROM."
So basically there are only 2 devices:
Redmi Note 4/4X SD625
Redmi Note 4 MTK
Sent from Xiaomi REDMI NOTE 4 using GAGT
wackykid
Redmi Note 4 MTK
oh yes... the phone i bought from qoo10... the box actually says redmi note 4... not 4X... but the hardware is SD625 plus the holes on the side is the same as the 4X one...
regards,
wacky
davidwong
So does it mean it's the same if I get from xiaomi Suntec/ Lazada Redmi note 4 or from QOO10 Redmi Note 4x right?
revhappy
Yes, the 3GB/32GB version should be identical whether you by RMN4 or RMN4X with the global ROM.
OmegaSupreme
My friend is interested in getting 1(note 4x sD625) and i realised newstar had upped e price to 235 on their Qoo10 site.
cscs3
LTE frequency band coverage is different. Cannot remember which one, one of the model has lte900 coverage.
revhappy
Yes, all 3 phones have different LTE frequency band coverage according to GSM Arena:
http://www.gsmarena.com/compare.php3?idPhone1=8580&idPhone2=8531&idPhone3=8291
Now I got the entire sequence of events.
1) In Aug 2016, Xiaomi launched RN4 MTK X20 in China, they called it Redmi Note 4
2) In Jan 2017, Xiaomi launched RN4 SD625 in India, with 3 LTE bands, they also called it Redmi Note 4
3) In Feb 2017, Xiaomi launched RN4 SD625 in China, with more LTE bands compared to India launch, this time to avoid confusion with the existing MTK version in China, they called this Redmi Note 4X.
4) In Mar 2017, this RN4X is the international version which was also launched in Singapore and called as Redmi Note 4.
So basically the local set that we get in Singapore is really RN4X. So on a broad level there are only 2 versions, the original MTK version and the SD625 version. For the SD625, 4 or 4X can be used interchangeably depending on whether you are in China or not in China :) Also the LTE bands on the SD625 can vary depending on whether it is India set or international set. The Russia version also supports same bands as the Singapore version.
https://translate.google.com.sg/translate?hl=en&sl=ru&u=http://www.mi.com/ru/note4/&prev=search
revhappy
Interestingly in China, both the MTK and the SD625 version are sold as "Redmi Note 4X"
The 3Gb version comes with SD625 Chip whereas the 4GB version comes with MTK X20 chip
https://translate.google.com.sg/tra...&u=http://www.mi.com/redminote4x/&prev=search
3GB memory standard version of the high-end Xiao Long processor - Xiao Long 625, the highest frequency of 2.0GHz, while running multiple programs, still smooth and comfortable, with advanced 14-nanometer process, better performance at the same time, more power Low, more durable use. Another 4GB memory version with a single-core frequency up to 2.1GHz Helio X20 ten-core flagship processor, equipped with third gear power saving technology, according to different scenes automatically switch
cscs3
You miss one between 1 and 2. Redmi note 4 also has SD processor version few months after the MTK version launch. Similar to Redmi note 4x, SD version first then MTK version.
Those 4x version sell by parallel importer has less LTE band coverage vs the 4 imported by Xioami Singapore which has LTE900 base on their web site. Anyone actually test it?
You can check that thru Xiaomi rom website. Both model as SD and MTK.
revhappy
Do you have any news link about it? From what I saw, the India version was the first SD version. On the Xiaomi Rom website, there is no China ROM for the SD version of RMN4. Only on the RMN4X page there is a China(3GB+32GB) ROM. This means that when RMN4X was launched, the SD version with all the bands was available.
I also noticed the ROM for Redmi Note 4 MTK China and Redmi Note 4X China (4GB+64Gb) are identical
http://en.miui.com/download-309.html#454
http://en.miui.com/download-321.html#478
May be this means there is no 64GB version of SD in China.
The xiaomi China website is super confusing. Why do they have both Redmi Note 4 and Note 4X pages and the 4GB+64GB version is overlapping in both pages and both are X20. I wonder why they kept in both places and what is there difference.
Rui2
Xiaomi also si bei kiam gan
Doesn't has a proper naming convention
Note 4
Note 4.1
Etc
This looks simpler
Lei Zhong not thinking sia
steven168z
from the comparion isn't the Xiaomi Redmi Note 4 (MediaTek) better as it has more network.
revhappy
According to GizmoChina, the X20 is much more powerful
https://www.gizmochina.com/2017/01/19/helio-x20-vs-snapdragon-625-chips-inside-redmi-note-4-versions-compared/
Logically makes sense too in China X20 is chosen for its 4GB version.
deckcard
The mediatek version won't hv much 3rd party roms support plus battery life will not be able to compete with sd625 version.
Think09
https://www.facebook.com/XiaomiSingapore/
Say hi to our 3 new additions to Singapore! From 10th May onwards you’ll be able to get your hands on Redmi 4X (3GB+32GB), Mi Note 2 (6GB+128GB), and Redmi Note 4 (4GB+64GB). Power up with your Mi phone of choice-
Redmi 4X (RRP S$219)
- Available in 3GB RAM + 32GB Flash, Gold and Dark Grey colours
- Snapdragon 435 octa-core processor
- 5" display, 2.5D front curved glass
- Premium metal body
- High capacity 4100mAh battery
Mi Note 2 (RRP S$799)
- Available in 6GB RAM + 128GB Flash, Black colour
- Snapdragon 821 Processor
- 5.7" flexible OLED display, front 3D glass and back 3D glass
- 22.56MP high-resolution camera
Redmi Note 4 (RRP from $259)
- Available in 4GB RAM + 64GB Flash (NEW! RRP S$309), 3GB RAM + 32GB Flash (RRP $259) Gold, Dark Grey, and Black colour
- Snapdragon 625, 14nm FinFET technology
- 5.5” display, 2.5D front curved glass
- High-capacity 4100mAh battery
- 13MP BSI CMOS camera with PDAF
