Xiaomi Redmi Note 4X
Got split screen after update?! :eek:
So it's like Samsung with multi windows?
Yes !
Kiwi8
Deluxe Member
Yeah Ninja Van delivered my purchase. Now waiting 72 hours to unlock the phone bootloader. :o
revhappy
My phone just got updated with MIUI 9. RN4 mtk doesn't have this update yet. So Snapdragon guys are lucky.
The only difference I noticed so far is that the time widget now has the weather graphic as well.
Also noticed that now you can split screens.
Sent from Xiaomi REDMI NOTE 4 using GAGT
eddy0505
don't know
another possibility is you lack the correct ADB driver
updated OTA. updated ADB driver. still cant unlock even after 4 days. tried all possible solutions online, seems like there are some like me cant unlocked even after 1 month. guess not fated with this phone. lol time to sell it. the only reason i bought it was to root, unlock and flash to RR rom.
windwaver
What ROM are you on? Have you used VPN to bind your account?
Kiwi8
Deluxe Member
Can also try asking question at the Xiaomi official forums.
One possibility can be that your MI account kena blacklisted from unlocking bootloader. So just ask those Xiaomi admins to check your account.
Alternative is to create a new MI account.
ceestudent
What is the tempered glass or screen protector do you guys use?
My tg from taozi (qoo seller) is really unusable. The white patch at the edge is so wide and unable to stick.
Kiwi8
Deluxe Member
If u buy normal tempered glass protector, make sure it's a slightly smaller size one, cos glass protector cannot bend, so can only cover the flat part of the phone glass and not the curved part.
If u want to cover even the curved part, then will have to buy those 2.5D rated protector.
ceestudent
Can recommend which tempered glass have smaller size? Let me know the link if you have it. Thanks
Kiwi8
Deluxe Member
ceestudent
Ok. I will order from the link you shared.
Wanted to buy 1 more set from lazada but the price increase by 20$ now :s13:
My experience is from the free TG protector that I got when I got the 3GB/16GB version a few months back.
So I just wanted to buy the same one for this 3GB/32GB version. I bought from AliExpress.
https://www.aliexpress.com/item/9H-...-3X-3PRO-NOTE-2-3-PRO-XIAOMI/32759792155.html
U may want to choose another protector if u want to cover the curved part too.
SkyShroud
did you confirm fastboot.exe can see your device?
wackykid
a question... did anyone update the OS to MIUI 9...? it seems that easy mode is gone...?? my mum is now complaining because the phone updated the OS... and now she is struggling to use the phone...
anyway to enable back easy mode or workaround to mimick one...?
regards,
wacky
Kiwi8
Deluxe Member
regards,
wacky
There is a lite mode rite?
XClusivE.L
whats the latest price now ? also anyone can feedback on the gaming performance for this phone? games like ML, AoV and some others.
