Xiaomi Redmi Note 4X
Chevalier
got 64/4 redmi note 4 for 209 on carousell. export set global edition
the j7 pro was 305 on carousell too
anyway i went with the redmi note 4 in the end. didnt want to spend too much on a secondary phone.
ablurcat
Is your Redmi Note 4 Snapdragon ?
playtime
Hey my note 4 suddenly people cannot hear me but I can hear them... Any solutions?
Brought to see svc ctr and they just tell me nothing they can do.
Don even check the phone
ZrE0_Cha0s
Did you accidentally mute your voice? Maybe I can try voice recorder and see if u are able to play back your voice.
Centronics
any links to downgrade to miui 8.0?
with miui 9.2 my battery drain is very bad. phone can only last 3/4 day... previously was like can last 2 days or so:s12::s12:
ceestudent
Is there any custom rom that able to utilize the capacitive button instead of on-screen button?
Sent from Xiaomi REDMI NOTE 3 using GAGT
magixz
Really? I tot my battery gone case.
I want to buy another phone.
Sent from Xiaomi REDMI NOTE 4X using GAGT
We_Generation
Hi guys I realized recently my android system is draining my battery. May I know what happened? It used to be able to last very long but now it seems to drain quite fast that I have to charge every one day or so
magixz
I thinking of getting another note 4x cos current battery life not so good. But dunno is it due to firmware issue
wizardundo
If battery is draining fast, you can drain the battery to completely 0% then recharge it fully to 100%. I get that battery problem everytime they patched a new update, and battery went back to normal after I drained then recrharge. :s12:
windwaver
Before you get a new one, try unlocking bootloader then flash a custom ROM. Install a battery friendly kernel or under-volt CPU to get better battery life; less heat also.
