Xiaomi Redmi Note 4X
ZrE0_Cha0s
Before you get a new one, try unlocking bootloader then flash a custom ROM. Install a battery friendly kernel or under-volt CPU to get better battery life; less heat also.
By den again with SD 625 is already a power-effiecent SoC, still need to down-to-earth it?
windwaver
Yeah, the SD 625 is already very power and heat friendly. However, it can be even more friendly if you apply a few simple tweaks.
Doesn't really hurt, it took like 5 mins of my time ;)
Kiwi8
Deluxe Member
Guys, I dunno why, I simply cannot install TWRP on the phone.
Everytime I flash the img file to the phone via fastboot, after that upon selecting the option to boot to system, it will go blank.
Hailgod
bootloader unlocked?
Whisper
After updating to the latest software..how to delete the new page before the home screen?
ngbc
Did you use this command (temporary) :
[FONT=&quot]fastboot boot recovery.img[/FONT]
or this one (permanent) ?
[FONT=&quot]fastboot flash recovery recovery.img[/FONT][FONT=&quot][/FONT]
Better to rename twrp name to recovery.img
magixz
Anyone got a guide to flash the phone. I bought early last year should be bootstrap unlocked right? How to check?
Sent from Xiaomi REDMI NOTE 4X using GAGT
ZrE0_Cha0s
It's @lways on locked bootloader. U have to go over to the settings in developer to unlock it.
Hailgod
need to apply for unlock first as well.
anyway i found a better gcam version for my omnivision sensor. the trouble is now worth it.
magixz
Miflash unlock tool is a zip file run from phone or pc? Sorry, I noob ah.
Kiwi8
Deluxe Member
Yes this is what I did.
Anyway, from what I had been reading online, it seems that the TWRP doesn't seem to work for newer models of the XRN4X which use a newer display panel, and that the TWRP has to be rewritten to take that into account.
